NAS Vs Microserver
FreedomEclipse
~Technological Technocrat~
24,779 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Ive been working a fair bit recently. and while ive been working Ive had a lot of time to think what would be the next upgrade best upgrade for my system.
Unfortunately I have drawn a blank with this train of thought apart from my hard drives that could do with swapping out for new ones.
I have decided to go down the route of taking 2 or 3 of the hard drives out of my PC and putting them into a NAS or a HP Microserver.
The NAS Im looking at will be Netgear NAS Duo V2
Unfortunately I have heard mixed reviews about this and most reviews say that its speeds are generally pretty poor
With that in mind I have chosen a second option - HP ProLiant G7 N54L The OS of choice will most likely be FreeNas.
Both of these will be used for the same purpose - as a centerhub which all my media is stored on so that i can be streamed to any device on the network at any given time.
Im leaning towards the HP as they are offering a £100 rebate on it which will work out cheaper to buy then the netgear NAS.
With that said I currently have no idea which is the best bang for buck NAS out of the market
If you have any NAS recommendations or advice on setting up a Microserver - Id like to hear it.
12,062 (2.54/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
My friend on here UnholyWar bought the HP microserver with £100 cashback, and he couldnt be happier. He runs a boatload of stuff on there and streams everything around his house, and dumped a couple of 2TB drives in there, for storage, and also backing up all the PC's and laptops in the house. Great for file storage.
FreedomEclipse
24,779 (3.77/day)
what OS does he use with it?
12,062 (2.54/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
6,560 (1.01/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
Could go down the tip and salvage an old PC and then out free nas on it.
FreedomEclipse
24,779 (3.77/day)
I thought about this too. unfortunately I dont have a spare system and whatever spare system i do have is ATX size. Its just easier to run with a HP Microserver as building M-ITX rig would cost more the HP Microserver and i wouldnt get £100 back
Fourstaff
10,089 (1.79/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
I have heard good things about the HP microservers, I think you will not go wrong with it especially its cheaper than a NAS. NAS can be slow depending on the controller chip, but with this its at least "fast enough"
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
I rebuild an old Dell desktop into a file server with all new parts for $400 including 2 2TB WD reds for raid 1. I run win8 pro to use the Hyperv program to mess around with VMs as well. full specs of mine are in my sig.
FreedomEclipse
24,779 (3.77/day)
HP microserver still works out cheaper :p just not as powerful!
FreedomEclipse
24,779 (3.77/day)
Well, Ive made my decision and ive decided to go with a Microserver. Im not getting it right away as im waiting for pay day but I'll probably see if i can do a mini-review when i get it as there doesnt seem to be one on the forums
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
FreedomEclipse
24,779 (3.77/day)
yeah Ive been checking Synology out, they are pricier than Netgear but the reviews are generally more favorable from what ive seen.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
I've heard only good things about their products. They are a bit on the pricy side though, you're right. I would really hate to get something that wasn't good if you're going to be spending a decent amount of money on it anyways.
FreedomEclipse
24,779 (3.77/day)
I shall see!
the HP Proliant still works out cheaper by a fair bit
the Synology DS212j is $248, the HP ProLiant G7 N54L is $324 but gives $155 cashback so in the end the N54L works out at $168, is more powerful and can support/hold more hard drives.
It just boils down to how long i want to spend messing about with setting up pretty much. Obviously the synology will be up and ready to go in a matter of minutes as I dont really care to have hard drives in raid config. gonna move 2 of my hard drives from my PC into the NAS.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Ah, yeah. You have to configure that HP box as it's a mini-server practically. If you just need a NAS, I would go with the Synology box, otherwise that extra power won't be very useful. If you just want it to work, I wouldn't go with the HP. If you're planning on doing more than just a NAS, then the HP sounds like a decent plan if you can't build it yourself cheaper (it is a Turion CPU after all, it's not all that fast.)
FreedomEclipse
24,779 (3.77/day)
well, Im gonna hang on and see if i can score a good deal on some WD 3-4TB Reds while im waiting. Theres always so place offering some cut price deals
Fourstaff
10,089 (1.79/day)
Home
Not considering Greens instead (or indeed any other colour)?
FreedomEclipse
24,779 (3.77/day)
well since the 3TB WD Red is only £15 more then the 3TB green Id rather go for the red due to its longer warranty given the price.
Then theres the whole debate about the head parking wearing the drive out quicker then it should.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
The reds also have a higher platter density (1TB/platter), their performance is pretty good, and they have TLER. Everything you want in a drive that you might want to RAID.
FreedomEclipse
24,779 (3.77/day)
I dunno about RAID, I might run with a RAID 0 setup for the extra performance. Not that i really need it as the fastest speed on my network is 100mb. Its more or less going to be a media/file storage server for me to dump a few files on but mainly my music and video collection. hence the emphasis on 3-4TB hard drives
67 (0.01/day)
System Name Unholy Black
Processor Intel 3570K
Motherboard Gigabyte Z77X-D3H
Cooling Corsair H80i
Memory 16GB (8GB X2) Kingston hyper X 2400mhz
Video Card(s) MSI GTX 970
Storage 250 GB Crucial MX200,120 GB SanDisk Extreme SSD, 1TB SAMSUNG
Display(s) Asus PB278Q and Asus VE247
Case Corsair Air 540
Power Supply Cosair AX860i
Keyboard Corsair K95
just updated it and installed server 2012 i would get a micro server, like rcoon said £100 cash back so on cost me £97 + drives
FreedomEclipse
24,779 (3.77/day)
How much did that 2012 license set you back? :p
1,150 (0.20/day)
SCOTLAND!
System Name Machine XX
Processor Ryzen 7600
Cooling 120mm heatsink
Memory 32GB DDR5 6000 CL30
Video Card(s) RX5700XT 8Gb
Storage 280GB Optane 900p
Display(s) 19" + 23" + 17"
Case ATX
Power Supply 800W
Get the micro server, upgrade the ram to 8gb and stick ESXI (free) on it. this will let you run any OS simultaneously allowing you to to run a free linux NAS operating system like freenas or unraid to manage your hard drives and an old copy of xp for any applications.
This will give you the flexibility of upgrading your operating systems in the future without ever turning it off and trying new operating systems without disturbing the current ones.
You also have the option of expanding a micro servers capacity with esata and port multipliers if you ever needed the extra drives.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
It's a good idea, but considering what she is looking to use this for I think it's a bit overkill. I don't think that's the right option here because all it will be doing is storing video files. You don't need virtualization to do that. NAS devices don't tend to need to be flexible and that's what she's looking at doing. Just my 2 cents.
1,150 (0.20/day)
SCOTLAND!
Case ATX
Power Supply 800W
Yea if they are not comfortable with Linux the nas route would be simpler. But most of the things I mentioned are gui and have lots of guides on the net.
