Need A.S.A.P. help to open .ASPX file
9,019 (1.38/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
So I just bought and paid for tickets to go abroad. I did everything on-line.
I received an email with a link to print the tickets which I have to produce on embarkation.
Now this link doesn't open up at all. I tried Chrome and IE. No go.
If I choose to save the file it's in .aspx format.
I tried opening up using every program on my pc but it either refuses to open or I get a load of jargon symbols.
I googled the problem and found that .aspx should work if I open it with any browser whether IE, Chrome or FF.
Why isn't it opening up for me?
I'd appreciate quick replies... because I just paid a lot of money and wouldn't like to lose it! :(
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
What do you mean the link doesnt open up at all ? Do you just get a white blank page?
2,516 (0.46/day)
Canada
Is there no way to contact the ticket provider/s and/or travel agent/s?
Hope you get it sorted BP :)
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
I just get a "loading" symbol at the bottom left of the page. But the browser would be stopped. Not loading at all.
But there is a way to open up the .aspx file?
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
i have no idea but try checking your browser settings to allow scripts and what not. Either your browser is blocking the content or there is an authentication issue on the server you are trying to access.
Kreij
Senior Monkey Moderator
13,817 (2.08/day)
Cheeseland (Wisconsin, USA)
You can try to look at the source of the ASPX page, but that might not do you any good if the page is being created dynamically (highly likely as it is pulling ticketing information from a database or something).
Are you blocking cookies or popups (or whatever) that may be interfering with the page displaying?
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I just read if you have the file, as in not in the browser linking to it, you can rename it and see if paint or something will open it with a .jpg or .png
9,019 (1.38/day)
Processor i9 9900k
Keyboard Motospeed
Tried that. And pdf, doc, notepad, wordpad... :ohwell:
I either get this type of jargon:
†¿¡ƒþ`pØ?GGÃýà”¶^qŽ»u|ÔKk ªºØt‰‘¢ 0 s¨‹¥ø}ëø÷m/¥ ûså— Þš2{g+æïº0j] œJ“ú ¶@Ž—wèk~7¾šähú¸X¢Ï9z˜Ã •èÍl^–0Äï“O?æ_üí 9ÉG°†ì t7{ ~ŸsX”£ëüa4_>¯åxêÍÍ0
or it doesn't open up at all...
Kreij
13,817 (2.08/day)
Is it a secure link? (https:// ...,)
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
Just contact the vendor you purchased the tickets from.
Kreij
13,817 (2.08/day)
This should be resolved (waiting to hear from BP).
The site was creating a PDF and giving it an .aspx extension so nothing would open it (and why it was "gibberish" when viewed).
Changing the extension to .pdf allowed it to open in Acrobat Reader.
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Mouse MX Master 3s
right, but she should still contact the vendor as they are using a garbage system.
4,876 (0.78/day)
Joplin, Mo
System Name Ultrabeast GX2
Processor Intel Core 2 Duo E8500 @ 4.0GHZ 24/7
Motherboard Gigabit P35-DS3L
Cooling Rosewill RX24, Dual Slot Vid, Fan control
Memory 2x1gb 1066mhz@850MHZ DDR2
Video Card(s) 9800GX2 @ 690/1040
Storage 750/250/250/200 all WD 7200
Display(s) 24" DCLCD 2ms 1200p
Case Apevia
Audio Device(s) 7.1 Digital on-board, 5.1 digital hooked up
Power Supply 700W RAIDMAXXX SLI
Software winXP Pro
Benchmark Scores 17749 3DM06
This. Asp scripts are ran server-side like PHP. Seems like you might need to contact them.
Kreij
13,817 (2.08/day)
It worked fine for me in the browser with the Acrobat Reader plug-ins installed.
I sent her the .pdf and she still could not open it. :wtf:
Not sure why it's not working for BP.
I'm still using Reader 9 (9.5.2 to be exact) but any version of 10 should be fine too.
Maybe she has 8 or earlier on the computer she is using (shrug).
Anyway, TPUCapture to the rescue. :)
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
It could be a scam.
Kreij
13,817 (2.08/day)
It's not a scam.
It's just a problem with her computer.
