need advice lowering memory timings
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
so i plan to try to lower my memory timings so i need some guidance on this
dont tell me to google it.. i prefer to ask those who got expierance in this
what software do i need for stability testing?
what settings should i change? and what not?
im running Kingston Technology KSM32ED8/16HD, 16 GB, 2 x 16 GB, DDR4, 3200 MHz, 288-pin DIMM ECC cl 22
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
3200c16 is pretty limited
But you should look through the aida64 thread for similar memory post while you wait
3x0
1,014 (1.09/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB Noctua NF-A12x25 Edition
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Endgame Gear OP1 8K
Keyboard HyperX Alloy Origins Aqua
Deleted member 185158
First take some screen shots of what you have got going on.
Cpuz memory and SPD tabs.
Zen timings.
Could do Taiphoon Burner and screen shot the Eeprom information as well
3,719 (1.77/day)
Power Supply Corsair RM750x
Mouse Logitech M575
For quick testing I use passmark memtest86 but that won't catch a lot of other problems. Then I use OCCT.
There are some other programs people use for testing as well.
But you should also test against varying workloads.
Watch your error logs for WHEA errors. ECC corrections should show up in the logs if it happens.
Test your system running at idle and low workloads for spontaneous reboots.
One thing to test is for heat. If your workload generate a lot of ram heat you want to make sure to test for that so you know your overclock is stable at higher temps.
Personally I have found it more difficult to OC ECC (I'm not an expert) and have a terribly difficult time getting something worthwhile to run over DDR4-3200 but have had much more success simply raising voltages to reduce timings. For example from CL22 to CL16 to make it more like a typical CL16 kit. For me the primary timings, tCWL, and tRFC have been the easiest to improve but I don't have your model kit so YMMV.
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
Zen timings.
i start with installing the reqeusted software "memtest86" "Taiphoon Burner "
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Zen timings utility would also be nice to see.
11,095 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Keyboard 65% HE Keyboard
The timings on DDR4 that made the biggest difference for me, and ones that I usually go for first after setting primaries are:
TREFI
TRFC
TRRD
TRRDL
TFAW
The the bank / dimm read latencies.
Those usually account for 80-90% of my gains, these alone can boost FPS in bandwidth bottlenecked scenarios by 20%. You can also into a rabbit hole with ram timings for that last 1% boost really easily.
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
my ram modules didt came with heatsinks should i invest into heatsinks first??
wats OCCT?
where can i find the log for error corrections in windows 10?
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Yeah 3200c22 is ugly x6 :eek:
11,095 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
wats OCCT?
You don't need heatsinks. Those timings are brutal... you have a huge potential with these.
3,719 (1.77/day)
Mouse Logitech M575
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
This is likely a very long shot at 1.35v
3200 MHz CL18-20-20-40
Make sure you create a system image before screwing with timings it can corrupt an os pretty easily.
3,719 (1.77/day)
Mouse Logitech M575
Even running at CL22 with a remote session to cloud network and a 6 core windows VM running in the background and a browser with 20 tabs open my bench score is on par with CPU-Z.
Just saying you shouldn't expect dramatic gains in performance if you push it down to CL16 but you can improve CPU utilization with better timings.
When I first started ram OC I used to make a spreadsheet of timings in nanoseconds to help suggest timings at different frequencies and track my testing progress.
This is just to give you an idea, I don't expect these timings to work for you. Testing is a laborious process.
Taiphoon Burner will help give you the SPD chip values. Other values I just grab from BIOS/UEFI defaults or what's reported in ZenTimings.
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
huge list to choose from.. this is new for me :p
so i asume i should change CL?
and
TREFI
TRFC
TRRD
TRRDL
TFAW
?? lower by 1 value and test and repeat?
Here's a good guide, everything explained https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md
Good luck
Edit:
Yeah, I don't think you will have too much success overclocking RAM that supports ECC.
btw i heard that ECC ram is more stable in overclocking than non ecc. not sure if its true or not
i start tomorow with making a fresh back up of my OS tomorow
3x0
1,014 (1.09/day)
Memory chips that are used in ECC RAM don't have speed in mind but stability and error correction. Stable and slow.
9,340 (4.94/day)
Louisiana
Keyboard G710+x3
Yeah they might throw up just using dimm at 1.35v pretty much normal for c18/ c16 primary timings.
I can't find any 3200c20 and it's primary timings they might still be 1.2v
Might add zen timings/... to the op
3,719 (1.77/day)
Mouse Logitech M575
and
TREFI
TRFC
TRRD
TRRDL
TFAW
I tend to start with common voltages first 1.35 DRAM and 1.1 SOC before changing frequency or timings but it may depend on your ram IC what voltages you should use.
Finding an existing example for your ram kit (or similar chipped kits) will save you a lot of time and at least might help you know up front what won't work and take a lot of guess work out of the process.
ECC gives you reporting. So if you are on the edge of stability causing correctable errors you can find out easily. Uncorrectable errors will cause a reboot.
I've seen a tRFC chart posted in the forums here a few times. Maybe if someone who has it can repost it here that might be helpful.
Morgoth
Fueled by Sapphire
4,253 (0.66/day)
Netherlands
this is after 17min 20gb testing not sure if the ram heats the same way up as a cpu and gpu doe's with this test
ambient tempreture of the room is 22c got the heater on i assume these tempratures are good for stock settings
is there a way to run memtest with out running the OS ? or other testing software for ram?
talking about freqenchy i tough ryzen 5 5900x doest support over 3200 mhz ram speeds??
3,719 (1.77/day)
Mouse Logitech M575
That seems ok to me. If in doubt put a fan on it. For example when I did put a ridiculous heat spreader on my kit with active cooling this is what I got after stress testing for 1hr.
30 (0.04/day)
Processor AMD Ryzen 5
Memory 16GB DDR4
Storage Crucial P5 Plus (M.2 NVME PCIe 4.0)
Display(s) 27" QHD 144Hz
Power Supply Seasonic Focus GX
The CPU memory controller is only guaranteed to work up to 3200, and with JEDEC timings. However, most CPUs can exceed that and work with faster RAM and/or faster timings. Also read about keeping FCLK 1:1.
3,719 (1.77/day)
Mouse Logitech M575
Since you don't have a heat spreader you have the benefit of seeing the IC numbers on your chips. This might help you search for OC results using those chips.
11 (0.01/day)
Motherboard Gigabyte X570 Aorus Elite Wifi
Memory Kingston KSM32ED8/32HC 2x32GB DDR4 ECC 2Rx8 Hynix C
Video Card(s) ASUS Prime 5070 Ti
Storage Samsung 2TB 970 EVO Plus
Display(s) Alienware AW3225QF
Case Cooler Master MasterCase H500
Audio Device(s) GSX 1000 + Sennheiser Game One + Edifier R1280DB
Power Supply FSP 1200W PTM X Pro
Mouse Logitech G Pro X Superlight
Keyboard HyperX Alloy Elite RGB
How many correctables are you getting per month, etc?
Gskill doesn't have advance / cross RMA so I decided to jump on the ECC bandwagon.
