Need advice on a future upgrade
80 (0.05/day)
United States
Processor Intel i7 2600k @ Stock
Motherboard Asrock Z68 Pro 3
Cooling Corsair A70
Memory 16GB DDR3
Video Card(s) Nvidia Geforce GTX 970
Storage 1x Samsung 860 Evo 250GB, 2x WD 1TB HDD
Display(s) Samsung 2253BW
Case Silverstone RL06
Hello! I am planning to upgrade my system in the near future and need advice on the parts that I've chosen. I'll mostly be using it for gaming at 1080p, video editing, and potential streaming. I don't plan to overclock, however I might undervolt if it's worth my time. I do not want to use an Intel system as their new processors require Windows 11 for their E-cores to work, and I'm not willing to make that switch. My goal is to keep the price around $800, including the monitor.
This is the best combination I was able to come up with:
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor ($189.00 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 Black 66.17 CFM CPU Cooler
Motherboard: MSI B550-A PRO ATX AM4 Motherboard ($139.99 @ Amazon)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($76.99 @ Newegg)
Storage: Samsung 860 Evo 250 GB 2.5" Solid State Drive (Purchased For $0.00)
Storage: Western Digital Black 1 TB 3.5" 7200 RPM Internal Hard Drive (Purchased For $0.00)
Video Card: MSI MECH 2X OC Radeon RX 6650 XT 8 GB Video Card ($249.99 @ Newegg)
Case: Silverstone RL06 ATX Mid Tower Case (Purchased For $0.00)
Power Supply: Corsair RM850x 850 W 80+ Gold Certified Fully Modular ATX Power Supply (Purchased For $0.00)
Operating System: Microsoft Windows 10 Pro OEM - DVD 64-bit (Purchased For $0.00)
Monitor: LG 24GN600-B 24.0" 1920 x 1080 144 Hz Monitor ($150.00)
Total: $805.97
Any advice would be greatly appreciated!
2,037 (1.31/day)
Alaska USA
Make sure that cpu cooler will clear the heatsinks on that board.
DeepCool AG620 CPU Cooler $54.99
DeepCool AK620 CPU Cooler $64.99
https://www.tomshardware.com/reviews/deepcool-ak620-review
5,269 (0.86/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
The main reason I went AIO. To get decent tempts on air your cooler is obnoxiously large (and often times loud).
2,037 (1.31/day)
Alaska USA
I've always used air cooling so I can't compare. With that said I've never had any issues.
506 (0.25/day)
I'm not trying to sound snarky but this isn't really a concern given your scenario because 1.The 2 most obvious lga 1700 cpus in your price range don't even have e cores (12500 and 12600 non k) and 2. On most motherboards you can simply just turn off e cores via bios and never have to worry about it again.
80 (0.05/day)
United States
Cooling Corsair A70
Memory 16GB DDR3
I didn't know you could disable them, nice to know. However, going with AMD gets me two extra cores compared to the intel processors you listed.
9,340 (4.92/day)
Louisiana
Keyboard G710+x3
2,373 (0.55/day)
Audio Device(s) A LOT
What video editing software do you use?
80 (0.05/day)
United States
Cooling Corsair A70
Memory 16GB DDR3
2,373 (0.55/day)
CUDA is generally considered faster than OpenGL but whatever floats your boat
3,644 (1.13/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Nope, you can get a small air cooler that is both quiet, small, and good performing. The Noctua NH-U12A for example
Air coolers are still king when it comes to acoustic efficiency as well.
You really have to get an AIO over 240mm in size in order to get lower temps than you could have gotten with air and at that point you are already taking a ton of space in your case whether you go AIO or air. A 360mm loop is not small.
80 (0.05/day)
United States
Cooling Corsair A70
Memory 16GB DDR3
I know an Nvidia card would suit my needs a lot better, however they're a lot more expensive right now and can't justify spending $70-100 more for the same performance compared to AMD cards.
Looks good but this combo has better bang for bucks for another 130.us
Might check micro center to if you have one around I saw a combo there to with a msi tomahawk.
If I get some extra cash down the road, I might switch to this instead. Thanks for showing me this.
506 (0.25/day)
Which is nice in theory but practically wise it's a wash since those cores are weaker. The 12600 non K (which is slower than the current midrange raptor lake chips) for example tested 7% faster than the 5700x in 1080p gaming and only 1.5% slower in the overall application test.
I'm not saying don't buy the 5700X, i'm saying don't let E-cores or it having 2 more physical cores be the reason why because both those things are meaningless in real world usage. The Intel also gives you a decently superior upgrade path (higher-end 12th gen or any of the 13th gen you can get later down the road). There's even rumors that 14th gen might be on the same socket as well as a raptor lake refresh
AM4 is great for ultra budget new builds but for most mid-tier builds or higher I'd rather do Intel or save a little more for AM5 (I wish motherboards where cheaper on AM5 because it would make it a much more viable option for the average build)
JrRacinFan
Served 5k and counting ...
20,126 (3.04/day)
Youngstown, OH
System Name Snow White
Processor Ryzen 7900x3d
Motherboard AsRock B650E Steel Legend
Cooling Custom Water 1x420
Memory 32GB T-Force Deltas
Video Card(s) PowerColor 7900 XTX Liquid Devil
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Tt CTE 600 Snow Edition
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Corsair K65 Mini
Benchmark Scores Avermedia Live HD2
5,269 (0.86/day)
We have very different opinions on small and quiet.
479 (0.48/day)
Some Where On Earth
System Name Spam
Processor i9-12900K PL1=125 TA=56 PL2=288
Motherboard MSI MAG B660M Mortar WiFi DDR4
Cooling Scythe Kaze Flex 120mm ARGB Fans x1 / Alphacool Eisbaer 360
Memory Mushkin Red Line DDR4 4000 16Gb x2 18-22-22-42 1T
Video Card(s) Sapphire Pulse RX 7900 XT
Storage Team Group MP33 512Mb / 1Tb
Display(s) SAMSUNG Odyssey G50A (LS27AG500PNXZA) (2560x1440)
Case Lan-Li A3
Audio Device(s) Real Tek on Board Audio
Power Supply EVGA SuperNOVA 850 GM
Mouse M910-K
Keyboard K636CLO
Software WIN 11 Pro
Your build looks good, and I think for those on a tight budget, the AM4 planform with DDR4 has a good amount of life left in it. The only thing I would add, is a 512Gb PCI 3.0 NvME drive, which can be had for around 30$ to 35$ and would give you better performance than the SSD.
You might also want to see where the closest Micro Center is and take a look at their combo deals.
AM5 Deal AMD Ryzen 9 7900X, ASUS B650E-F ROG Strix Gaming WiFi, G.Skill Flare X5 Series 32GB DDR5-6000 Kit, Computer Build Combo - Micro Center (Would rase your budget by 70$)
AM4 Deal AMD Ryzen 7 5800X, ASUS B550-F ROG Strix Gaming WiFi II, CPU / Motherboard Combo - Micro Center (Would lower your cost by 29$)
dgianstefani
TPU Proofreader
5,468 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
AM4 only makes sense for a 5800X3D build at this point.
Go 13600K if you can afford it, and if you can't, 12400.
E cores, 10/11 is irrelevant.
What you're really doing is trying to compromise, and ending up with a last gen build with performance from around two years ago.
In my opinion, this is a complete waste of $800.
It's the same for spending money on a 1080p display, if you aren't an esports player getting a 480 Hz display, it's silly.
Get 1440p or 4K.
Your argument for "same performance as NVIDIA but $100 cheaper" is also strange, considering in the workloads you'll be doing, AMD is not the same performance as NVIDIA.
If you're streaming, E cores are extremely useful at mitigating performance lost.
10/11 is irrelevant, just use process lasso if you really care that much about potential lost performance by the wrong scheduler decision (not a big problem).
80 (0.05/day)
United States
Cooling Corsair A70
Memory 16GB DDR3
So I've started to realize that my assumptions were a bit naïve. I've decided to make a new list after reading all of the suggestions and came up with this:
CPU: Intel Core i5-12400 2.5 GHz 6-Core Processor ($182.99 @ Amazon)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler ($42.90 @ Amazon)
Motherboard: ASRock B760 Pro RS ATX LGA1700 Motherboard ($139.99 @ Newegg)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($112.22 @ Amazon)
Storage: TEAMGROUP MP33 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($29.99 @ Newegg)
Storage: Western Digital WD_BLACK 1 TB 3.5" 7200 RPM Internal Hard Drive (Purchased For $0.00)
Video Card: Zotac GAMING Twin Edge OC GeForce RTX 3060 Ti LHR 8 GB Video Card ($409.99 @ Newegg)
Total: $1068.08
I've decided to keep the monitor since my main goal with this build is to play games at 1080p at a high refresh rate (and it's still a huge upgrade compared to what I currently have). I'm willing to bite the bullet for an Nvidia card since they have many features that cater to content creation (NVENC, CUDA, etc). This is the best I was able to come up with, so any suggestions would be greatly appreciated!
2,037 (1.31/day)
Alaska USA
Total: $1068.08
If you're doing content creation then I'd look at the 13400 or 13400F (no integrated graphics). The G.Skill Flare series RAM has AMD Expo but I'd make sure it has XMP for your Intel build. One other thing to keep in mind. The RTX 4070 and 4060 are due for release this April and if those cards are anything like the recent 40XX cards that have been released they are going to be gaming beast. The 4060 should have a MSRP of $400. The 4070 Ti literally destroys the more expensive 3080 so that gives you an idea of what the 4060 might do vs the 3060 Ti.
https://pcpartpicker.com/product/VNkWGX/intel-core-i5-13400f-25-ghz-10-core-processor-bx8071513400f
Intel Core i5-13400F $209.95
For the same price here's a monitor with a higher refresh rate and G-Sync Compatible.
https://www.gigabyte.com/us/Monitor/G24F-2#kf
Unlike the Thermalright Assasin, this cooler has no problems clearing the heatsinks on the typical motherboard.
https://pcpartpicker.com/product/JN8bt6/deepcool-ak500-6899-cfm-cpu-cooler-r-ak500-bknnmt-g
DeepCool AK500 CPU Cooler $49.99
https://www.tomshardware.com/reviews/deepcool-ak500-review
2,373 (0.55/day)
I’d still consider the Assassin, just check to see if it fits. It won’t matter much with an i5 but it’s a significantly better cooler than the AK500.
Deleted member 223428
Total: $1068.08
Consider this memory kit (Intel XMP) over the one you have listed (AMD EXPO). It's also much lower latency (CL30 vs. CL36)
2,037 (1.31/day)
Alaska USA
A $30 cooler will handle either of these cpu's. The AK500 is overkill if anything.
Processor Base Power: 65W
Maximum Turbo Power: 117W
https://ark.intel.com/content/www/u...3400f-processor-20m-cache-up-to-4-60-ghz.html
Maximum Turbo Power: 148W
9,340 (4.92/day)
Louisiana
Keyboard G710+x3
Total: $1068.08
That gpu would do well on 5800x3d as well with no need for a cpu later
Then you can only upgrade storage later.
JrRacinFan
20,126 (3.04/day)
Youngstown, OH
Storage 20+ TB
And if @Soup` were to upgrade cpu further down the line say ... 13700kf ....
2,037 (1.31/day)
Alaska USA
Then he can get a cpu cooler that doesn't interfere with the heatsinks and there's plenty of them starting with the Deepcool AK620, AG620, Noctua nh-d15, be quiet! dark rock pro 4, etc ...
