- Mar 17, 2014
- 152 (0.04/day)
Processor | Amd Ryzen 7 Pro 1700@3.6Ghz |
Motherboard | Asus Prime B350 Plus (needed pci slot for Ht Omega Claro Halo) |
Cooling | Noctua C-14 |
Memory | 16GB A-Data DDR4-3200 |
Video Card(s) | AMD Radeon Pro Duo |
Storage | Patriot Torch 512gb, Seagate Barracuda 512gb , Adata 128gb SSDs & 1TB Western Digital Black |
Display(s) | Seiki 39" 4k |
Case | MetallicGear Neo Air |
Audio Device(s) | Ht Omega Claro Halo |
Power Supply | Rosewill Glacier 850 watts |
Mouse | Ancient Razor Diamondback |
Keyboard | Logitech Illuminated |
Software | Windows 10 Home 64-Bit |
I've tried a few and when windows loads it eventually freezes with the card installed. This is a dual fan card with a bios switch. Someone put an r9 290x bios on other side of switch and it won't flash back to an r9 290. So both bios's are not working properly. Windows freeze and backscreens. I tried the bioses listed on this site but they wont work either. http://kju135.egloos.com/m/1436206
Under the heatsink it as Elpida memory, nothing on the gpu chip and says LF R29FA on theboard.
