Need help on whether to clear TPM on not
696 (0.16/day)
India
System Name To be ALL IN ONE MACHINE. but not yet
Processor i7 3770k
Motherboard Asus P8Z&&-V Deluxe
Cooling Thermalright Silver Arrow
Memory Gskill Ripjaws 1600Mhz 8GB *4 = 32GB
Storage Samsung pro 840 256GB, Segate 3TB and 1TB
Display(s) LG 23" Full HD LED
Case Antec LanBoy Air
Power Supply Cooler Master M2 Silent Pro 850 Watts
Software Windows 7 ulimate 64bit
Hi guys,
I was doing reset my Windows 10 Dell 5559 laptop to factory Setting.
got this message after screen had stuck on 99% during reset the message displayed is
"A configuration change was requested to clear this computer's TPM (Trusted Platform Module)
WARNING: Clearing erases information stored on the TPM. You will lose all created keys and access to data encrypted by these keys.
Press F12 or Volume Up to clear the TPM Press ESC or Volume Down to reject the change request and continue"
I tried a lot to know what it is actually ,but failed to understand
I just don't know whether to press F12 or ESC, and what if I press ESC is it ok?
(please advise , the laptop is running since 8 hours.)
Thanks
Ebo
778 (0.18/day)
Nykoebing Mors, Denmark
System Name the little fart
Processor AMD Ryzen 2600X
Motherboard MSI x470 gaming plus
Cooling Noctua NH-C14S
Memory 16 GB G.Skill Ripjaw 2400Mhz DDR 4
Video Card(s) Sapphire RX Vega 56 Pulse
Storage 1 Crucial MX100 512GB SSD,1 Crucial MX500 2TB SSD, 1 1,5TB WD Black Caviar, 1 4TB WD RED HD
Display(s) IIyama XUB2792QSU IPS 2560x1440
Case White Lian-Li PC-011 Dynamic
Audio Device(s) Asus Xonar SE pci-e card
Power Supply Thermaltake DPS G 1050 watt Digital PSU
Mouse Steelseries Sensei
Keyboard Corsair K70
Software windows 10 64 pro bit
Do you have anything encrypted on it ?
Do you have any keys stored on the computer that you need and havent either written down, or stored on a USB stick ?
If you can say no to these 2 questions, its safe to press F12, if not press esc and everythign just goes back to the way it was.
696 (0.16/day)
India
Processor i7 3770k
The situation is like this:-
I bought Dell i7 6th Gen laptop on 27th, today I am about to return it as it has some scratches on it( seller agreed on it) so I decided to do reset in windows 10 , but stuck to above error
I have no personal data on it, I just want to restore this laptop to factory setting ( to a screen which appears the first moment you switched ON the brand new laptop asking for Country and language)
What if I press ESC here, will it restore to factory setting?
Ebo
778 (0.18/day)
In that case, I would just let it be, and return it the way it is, because you havent done anything wrong and just let the seller deal with it.
696 (0.16/day)
India
Processor i7 3770k
Should I Press ESC now?
Ebo
778 (0.18/day)
I would
696 (0.16/day)
India
Processor i7 3770k
Thanks a lot Ebo! The problem is solved, I pressed F12 becuase ESC was contineously displaying the same screen again after Reboot as I had chosen the wipe the entire drive option; after pressing F12 the problem is solved. and Laptop is returned.
:lovetpu:
  • Like
Reactions: Ebo
Richa
1 (0.00/day)
Hi OP, I'm facing a Similar issue, I just need to know one thing, after you cleared the TPM, did you have to enter the Product Activation Key for the Operating System itself?
18,584 (2.64/day)
System Name AlderLake
Ok I didn't had laptops with TPM but I never had to enter the windows activation key after a reinstall from the recovery partition.
Dheeraj
1 (0.00/day)
I also wanted to know the same thing. I'm having an issue with my motherboard, and resetting by removing the battery didn't help. So wanted to do full bios reset. I'm not sure if clearing TPM will cause losing of the Windows 10 license. Did it worked for u?
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Clearing the TPM will not remove a windows license. Windows 10 at least does not utilize the TPM for licensing purposes.
I should know, I switched one out completely just recently.
Wolfs2424
2 (0.00/day)
Would no exept my password. Worked perfectly, took 4 hours exactly for me. after witch I got this message:
WARNING: Clearing erases information stored on the TPM. You will lose all created keys and encrypted data and stored keys.
Press F12 or Volume Up to clear the TPM Press ESC or Volume Down to reject the change request and continue")
I pressed F12 and Installing windows shows on screen, it took another 30 minutes. If you have anything incripted or special keys that will be erased to factory as well. (Total time of 4 hours 30 minutes). By the way my computer was new and would not let me log in.
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Sounds like it was using the tpm to encrypt the main drive. Certainly not the norm. Also, the fact that you could not log in suggests the computer may be illegally repackaged or stolen.
Where did you buy this?
Wolfs2424
2 (0.00/day)
Bougt it at Best Buy, brand new in the box. Everything is fine now, just the pasword was probably entered wrong the first time. No trouble logging in now
22,161 (3.43/day)
Olympia, WA
System Name Pioneer
Ok, that's certainly different but doesn't sound suggestive of theft if you bought it at a big chain store like that. Thanks for the report. :)
codyb
1 (0.00/day)
Okay so one of our employees called a number on a pop up and allowed someone who claimed to be from Microsoft to remotely connect to his Surface Pro. When starting up the computer there was a password before you can log in to Windows - that is the Bitlocker Virus, they want you to pay them money to get your property/data and access back to your computer. The only way I could fix this was to hold 0 and power on, troubleshoot and restore from cloud. WHEN IT ASKS TO CLEAR TPM YOU MUST SAY YES to start over (factory reset) - the data that the hacker encrypted and set a password on is gone, atleast from my experience... to difficult to mess with just reset and clear tpm and start over. If you never paid for software like Bitlocker or encrypted data on your computer then you were probably compromised and someone is holding this hostage. Once this is complete you just sign into Windows (atleast with Windows 10). Select language and proceed to setup this machine. Never call a number on a pop up or allow someone that claims to be from Microsoft or anywhere to remotely connect to your pc - that's ransomware. Hope this helps!
18,584 (2.64/day)
You just came a little late to the party though! :rolleyes:
Jophus0124
3 (0.00/day)
Hi I have the same problem on my Windows Surface 8 pro and when i got it it had Windows 10 installed, I got it from the pawn shop and i was gonna reset it and i got the same, my question is can i use on screen keyboard for this or i need to purchase the keyboard for this Thank You
1,080 (0.15/day)
Look behind you!!
System Name NEW
Processor Intel 4770 non-K
Motherboard Gigabyte H81M-DS2V
Cooling CM Hyper 212 plus
Memory 16gb Muskin
Video Card(s) XFX 380X 4gb
Storage Sandisk 120gb plus WD blue 1tb
Display(s) AOC 23.5 LED bl
Case XIGMATEK
Audio Device(s) motherboard
Power Supply Cooler Master 500
Use your volume keys up for yes down for no.
1,080 (0.15/day)
Look behind you!!
System Name NEW
Memory 16gb Muskin
Case XIGMATEK
That's what the OP posted. Not sure if yours is different.
Volume button - up to except TPM
Volume button- down to reject TPM
Sorry. Maybe a keyboard would help in your situation.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
5 new members in one thread? 'Splain that.
1,080 (0.15/day)
Look behind you!!
System Name NEW
Memory 16gb Muskin
Case XIGMATEK
Ikr!! Was wondering the same thing.
TPM.. TPU.. Something or other maybe
