Need help searching for a message tone
8,327 (1.29/day)
Processor AMD Ryzen 7 9800X3D w/ Corsair iCue Link H150i LCD
Motherboard ASUS ROG Strix X870E-E Gaming WiFi
Cooling 10x120mm Corsair QX120 RGB fans
Memory Corsair Dominator Titanium RGB DDR5 RAM 32GB (2x16GB) DDR5 7000MHz CL34
Storage Crucial T700 1TB Gen5, Samsung 990 PRO Series - 2TB PCIe Gen4, Crucial P3 Plus 1TB PCIe Gen4
Display(s) Acer Predator XB323U
Case Corsair 6500D Airflow with 10xiCue Link QX120 case fans
Power Supply Corsair RM1000x Shift
Mouse Logitech G604s
I need help from someone regarding a message tone that I used to have for my LG shine Cu720. I want to get the file and put it on my galaxy S3. I cannot find my phone charger nor do I know how to hook it up to my computer to try and get the file I want off of it.
If anyone has an LG shine or something lying around or can find a place online (cause i cant seem to find one) that has all the default ringtones/message tones to download that would be fantastic. Or even a cable that I can plug into the device itself and hook it up to my computer that would be fantastic as well.
Or you can try zedge.net for ringtones you can either email or download them. If you are doing it from your phone it is easier yet. Or not.... just looked really did not see much for you.
record a fart and use it
Tried that already. No dice.
Not helpful in the least.
You may need to use BitPim or the LG Shine Software Suite to gain access to the phone; as well as the USB driver.
If you need an unlock code... and, it is an AT&T phone, you can call them and they should give you one.
Need help connecting my LG CU720 Shine to my computer via USB cable? <--- Info, here. And the link in that thread did not work, however, I linked the usb driver.
I haven't tried that phone, so I don't know the particulars. But after reading around a tad... it seems AT&T locks their phone and it makes it difficult for the normal user to even get photos or contacts from the internal memory.
Maybe you need to go to your phone settings and set the USB settings to ''mass storage'' that way it will act as a storage device. That may allow you to open the stuff on the phone, I'm not sure. I never had to install and usb driver just plug it in the usb and it worked. When I plug in my phone it appears as 2 partitions. In one partition I have the images,videos,documents from my phones internal memory and on the other partition I have the images,videos,documents from my 2GB micro SD card.
