i do not have any v-sync enabledwhat do you have the Nvidia control panel set to for Preferred Refresh rate?
I know If I have it set to fast No man's sky runs weird. I get high frame rates, but the frame times are slower than what they should be. example I get like 30ms for something like 150fps which is totally wrong.
It when I use DSR to set 4K they end being normal back to 16ms for 60fps. Turing the setting back to application controlled fixes the odd Frame timing & micro stuttering issue.
I'm 100% sure nothing will change because before Atlas i was running normal windows but gonna try anywayThat would have been good to lead with, honestly. There is no way to know how butchered this install of OS with. Scrap and try with a fresh, clean stock image. Any tweaks should be manual and with a full knowledge of what you’re actually doing to the system. Jesus Christ. “As light as possible” isn’t a positive that you might think it is.
