ArcticFox1977
- Jan 12, 2022
- 16 (0.01/day)
Hi fairly new to this. So if you are replying make it for beginners.
Currently have a master cooler TD500 white case
CPU i5 12600KF
MOTHERBOARD- gigabyte z690 gaming x ddr4
PSU- 1000w
RAM- 16gb
I have no CPU cooler yet or GPU. Cooler is on its way and obviously GPU's are hard to come by.
Anyway, cpu installed and ram and psu. Connected the CPU cable to the top right on MOBO and connected the big 24 pin power cable. Connected the USB 3 cable along with the audio and front panel cables. The fans on the case i have connected to the regulator that comes with it and connected this via sata cable to the back of the PSU. The other end of the fans cables i have connected into the socket labeled sys fan 1. I wonder if this is correct? There is also sys fan 2, sys fan 3 and sys fan 4/pump at the bottom. I have checked the manual and the pictures and description arent clear. It states to plug it into the sys fan at the top near the CPU fan socket.
I have tried turning the pc on to see if they spin and light up and nothing. The RAM rgb's light up and look good but nothing else spins or lights up. Please help.
Thanks.
CPU i5 12600KF
PSU- 1000w
RAM- 16gb
Thanks.
