need help with clockgen
yanahs
21 (0.00/day)
Processor Intel E8400 @ 3.99ghz @1.376v
Motherboard DFI Lanparty Dark X38 T2R
Cooling Noctua NH-U12P Push Pull Fan
Memory Team Extreem Dark 2x1gb pc8500
Video Card(s) HIS hd 4850 @ 800/1100 Accelero S1 Cooler
Storage Seagate 160gb SataII
Display(s) Hanspree New York 19"
Power Supply Blue Storm II 500w
hi guyz.. I'm trying to use clockgen.. but cant seem to find the right pll chip?
I'm using a dfi lp dk x38 (i cant find any ICS,IDT) all i found was ITE IT8718f.. is there an update for clockgen? or any alternatives? thanx
overclock through the bios ?
Hit "Delete" when you see the DFI logo screen after you turn your computer on. Thats where you are supost to OC.
actually I've oc my rig to run @ 478 x 9 @ 1,4 volts..(in bios) I was just wondering if I could get higher.. since when I try higher settings the comp just wont boot.. so I was thinking startup at what I have and tweak higher in windows?
Well every chip is different. Could just be hitting an FSB wall. Post a list of all your settings you have set in Genie bios so we can possibly help assist in pushing further.
google setFSB!
you should use SETFSB program in it you can find your PLL because I use DFI too www13.plala.or.jp/setfsb
