Need Help With File Sharing over a network
105 (0.03/day)
System Name Omega
Processor AMD Ryzen 5 1600 6 Core
Motherboard GIGABYTE GA-AB350-GAMING 3
Cooling Air
Memory CORSAIR Vengeance LPX 32GB (4 x 8GB) 2666mhz
Video Card(s) MSI Gaming GeForce RTX 3060 12G
Storage 1TB SSD (OS drive) 2TB ssd, 2x 3TB HDD, 4tb m.2 ssd, 4,8 and 14tb usb 3.0 external
Display(s) Dell S-Series 27-Inch Screen LED-Lit Gaming Monitor (S2719DGF); QHD (2560 x 1440)
Case Rosewill Thor
Power Supply OCZ 750w
Mouse Logitech G502 hero
Keyboard Steelseries apex 7
ok not sure if this is actually the right place for this so if not i jsut pray it gets moved and not deleted lol
OK
i need help setting up my file sharing over my Home network
i have an OOOOOOLLLLDDD windows xp Laptop and my gaming tower which has 8.1 on it
i've googled my brains out and couldn't find a solution
basically i wanna share a few folders from my 3tb slave drive so i can access them from my XP machine
but apparently just doing the whole, R-click, Properties, share this folder, etc etc isn't enough
i know the folders are supposed to show up on my laptop under my network places
but they wont' show
i had it working before but then my laptop caught a real nasty virus and i had to redo the os -_-
so any help is appreciated
thanks in advance!!!
Do you have file and print sharing in the firewall settings enabled?
Go to advanced sharing>permissions>add user "everybody">full control if needed.
if that doesn't work then: on the same list where "everybody" is>add>advanced>find now>select the guests groups/users>click ok>repeat with each desired group/user type>ok to close all dialogs.
tried that.
no go
also i forgot to mention..
for some odd reason my whole 3tb slave is set to read only and keeps defaulting to that even after i disable it
thoughts?
I would do some disk checks on that volume. also check stuff like bios, etc.
I was never able to do this. I installed 7 on all my PCs to solve the problem. Really shouldn't be that hard but I worked on it for days
First we have to figure out if you can even get access to the computer you are trying to share you files from. So on the XP computer go to network places and type \\ComputerName, where ComputerName is the name of the Windows 8 computer you are sharing the files from.
That should allow you to see the share, even if you don't have permission to access it, you will still be able to see that the computer is sharing it. If you get an error and can't access the computer at all, then that is the first hurdle we need to address. It might also ask you for a username and password, put in the username and password for the Windows 8 computer.
Once you have access to the Windows 8 computer and can see the share, double click on it. If it lets you in, then you are golden. If it gives you an error, that is the next hurdle we need to tackle.
*sigh* nothing works
i also can't get my slave drives files and folders off Read only -_-
UPDATE:
what the...
ALL my drives are on read only o.O
yet they're working as they should...
#confused
well 7 is NOT and option for my laptop as it requires too much ram, cpu, etc
it's a old dual core with 1gb ram lol
UPDATE:
what the...
ALL my drives are on read only o_O
#confused
If the read only box has a square in it, that just means some of the files are read only. If it has a check mark that means all the files are read only. It is normal for most folders to show up with a square in the box with Windows 8 for some reason.
this can definitely be made to work, as i do it in my house easily.
that said, there is so many steps along the way you've ignored and not told us about, you REALLY need to go back to the basics and start from scratch.
share a folder, and see if you can connect manually via the IP address of the system.
do NOT ever expect the shares to magically just show up in the networking section of windows XP, that was an old, buggy, almost useless feature that never really worked right.
odd... i'm positive i replied to this earlier....
where'd my posts go? o.o
regardless
how do i connect manually to my 8.1 machine's share from my xp laptop?
it's under my network places right?
You might be able to manually connect via IP but its not just going to show up under networks
regardless
IP and IP only.
