Need help with GPU P-State bug
FNSaver
2 (0.00/day)
Hello guys,
I'd like to thank everyone beforehand for reading. I'm bolding some words to make it easier to skim through.
I have an ASUS G750JZ laptop with 4GB GTX 880M. Before this one I had never encountered any problems with the laptop or the GPU and it's quite weird and I am running out of patience. Basically, what happens is that whenever there is no monitoring software running which shows the clocks, the GPU runs at P-State P0, which means it's running at the max clocks. This happens even on idle. However, as soon as I run any monitoring software such as GPU-Z, HWInfo or Nvidia Inspector, the clocks go back to normal and the GPU idles normally. The P-State goes back to P8 - the state it should be when it's idle.
I have tracked GPU usage using Process Explorer and there is no difference in GPU usage with or without a monitoring software running. At idle, the only two processes which show GPU usage are csrss.exe and dwm.exe which are both Windows processes. I'm dying for a solution for this because I bought the machine while I was working in a different country where I made more money, and it's impossible for me to replace it or get something that's nearly as good with my current wages.
The troubleshooting processes I went through have been going through countless different driver versions using DDU and 2 clean Windows reinstalls.
I am using Windows 7 Ultimate 64-bit.
Has anyone encountered a problem like this before? I'm open to any and all suggestions. Thanks in advance.
PS: Have never used any modded drivers.
Hello guys,
What driver version you running on the GTX? Welcome to TPU :lovetpu:
EDIT also be sure you have installed your motherboard drivers after installing the OS! Start with the chipset driver then reboot and install the rest of the mobo drivers. Your GPU should be using Nvidia driver version V9.18.13.3302.02
Thank you :) I'm currently running 364.72. I reverted to these because I had it on when I first bought the computer last year and they always worked well for me. Plus, the latest versions have telemetry and that's one thing I don't need.
