Need help with undervolting Radeon RX 550
313 (0.12/day)
Hello all,
I would like to undervolt my Radeon RX 550.
So I would like to please you help me with the value of the voltage.
40,435 (6.56/day)
Hello all,
Use wattman/ afterburner or the tool your specific card maker provides
40,435 (6.56/day)
1,978 (1.79/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
Thank you.
But could you help me with the values of the voltage please?
Basically you go lower and lower, until it's not stable anymore. Finding the right voltage is trial and error and depends on card. Nobody will tell you what exact values will work with your card.
40,435 (6.56/day)
Just like dropping the vcore
RogerK88
21 (0.02/day)
Thank you.
There's not going to be a "specific voltage", and depends what memory type, and what the application is.
If it is mining, then you could try
GPU: 1150Mhz/840mV
VRAM 2050MhZ/840mV
313 (0.12/day)
GPU: 1150Mhz/840mV
VRAM 2050MhZ/840mV
Thank you for replying.
No,it is not mining.
