Need original VBIOS for Gigabyte GTX 1050 Ti GV-N105TOC-4GD with Hynix memory
stepan1475
6 (0.02/day)
Hi everyone,
I’m looking for the original VBIOS for my Gigabyte GTX 1050 Ti GV-N105TOC-4GD. The card has Hynix memory, which is clearly printed on the memory chips.
Unfortunately, the card was flashed with the wrong BIOS in the past, and now I’m trying to restore it. Most of the available BIOS files online (TechPowerUp included) seem to be for Samsung, Micron, or Elpida memory – but I couldn’t find one for Hynix.
Problem:
The card works fine in Windows without drivers, but as soon as I install the NVIDIA driver, the screen gets artifacts – grainy image, color blocks, and glitches. Clearly a VBIOS/memory mismatch.
Details:
Model: GV-N105TOC-4GD
SN: 181941019995
VRAM: 4GB GDDR5 Hynix
If possible, I’d also appreciate knowing the correct VBIOS version name (e.g. 86.07.xx.xx.xx) used for this card.
If anyone has the same card and can share a GPU-Z BIOS dump, it would really help.
Thanks in advance!
You can find it in vga bios collection
Also youtube has a good video on flashing the card
Whats your current VBIOS version?
Make its backup and post a screenshot of main GPU-Z window here before flashing anything.
Regarding the Hynix support - it seems to be added only in post-initial-release production, so it is available only as user-uploaded variant, not as official one from review sample.
Thanks for the replay.
Here is my current VBIOS version and GPU-Z screen shot attached.
I was not aware Hynix was only supported in later Bios versions that make sense now. Hopefully someone with a matching card can share their VBIOS.
The VBIOS currently on the card is clearly incorrect .
Thanks again for your help.
  • GP107.rom
    GP107.rom
Here is pictures of the card showing Hynix memory
Yes, this bios i dowloaded from techpowerup in hope it will be the right one. But unfortunately its not correct.
Just to add: I also downloaded and tested a few other VBIOS files from TechPowerUp for the same model, and some of them did show the BIOS version correctly in GPU-Z. But the current one (GV-N105TOC-4GD/FL0/099B) doesn’t show any BIOS version at all in GPU-Z.
That’s why I suspect this specific BIOS file might be corrupted, modified, or not fully compatible – even if it's supposed to support Hynix memory.
So I’m still hoping someone with the exact same card and Hynix memory can upload their own BIOS dump.
Thanks again for your help!
