Need Some Help Please
Glazierman
100 (0.02/day)
Lake Tawakoni,Texas
System Name CoolerMaster S.S.Gaming Mouse/Logitech G-13 Pad
Processor Intel Core i7-950 Bloomfield
Motherboard Asus Rampage II Extreme
Cooling Zalman CNPS10X cpu / 5-Aerocool S.Q.BLU-LED140 MM
Memory G.Skill Ripjaws DDR3 1600 12-GB
Video Card(s) 2-XFX HD-6990's-Crossfired
Storage OCZ Vertex Turbo ssd 60G / W.D. 1-TB. X2 (Raid 0)
Display(s) Sceptre 24" Black 1080P 2mcs
Case Thermaltake Xaser VI ATX Full Tower Black & Silver
Audio Device(s) Asus Xonar D2X / Roccat Kave 5.1 True Surround H.S.
Power Supply Ultra X4 1.6 KW
Software Windows 7 Ultimate 64-Bit
Thanks for looking, hope this is where I post this I'm having real trouble with my computer it's got a lot of problems in the event viewer here's the first one and I'll post others later.
Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-LoadPerf" Guid="{122EE297-BB47-41AE-B265-1CA8D1886D40}" />
<EventID>3012</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2010-07-09T23:22:30.929368400Z" />
<EventRecordID>18765</EventRecordID>
<Correlation />
<Execution ProcessID="792" ThreadID="2416" />
<Channel>Application</Channel>
<Computer>GlaziersGamer</Computer>
<Security UserID="S-1-5-18" />
</System>
- <UserData>
- <EventXML xmlns:auto-ns2="http://schemas.microsoft.com/win/2004/08/events" xmlns="LoadPerf">
<param1>Performance</param1>
<binaryDataSize>16</binaryDataSize>
<binaryData>37070000000000000000000009030000</binaryData>
</EventXML>
</UserData>
</Event
any ideas?? And thanks for any help
looks too me like one of your programs has a memory leak. what else can you tell us about these "problems"?
OMG! What did you do>?! You cracked the code that unlocks Windows!! JK
Not totally exactly what i was thinking, Sol. Maybe dying/bad ram?
@Glazierman
How long has the BSOD's been happenning? And can you replicate/make it BSOD?
reply
I can play BFBC2 and it crashes sometimes in minutes, other times in an hour?? but it only crashes when I'm in game. I had heard somewhere where the voltage was raised for the memory, but I have not done any kind of tweaking . REALLY!!
Anything overclocked at all? What's the specs of said rig?
The only think I've done is raise the fan speed becouse these black cards run real warm
Event ID 3012
"Performance counters are collected and used by services and applications. If they are installed incorrectly or with improper permissions
reinstall.
this would be the third time in two weeks??
start updating stuff/ patching it. though you will probably answer you already have. at which point i will demand you give us all the information you have instead of playing 20 questions. what have you done to fix it? have u re installed DX? have you updated windows? have you updated the game? punk buster? tried 95's suggestions?
next
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Search" Guid="{CA4E628D-8567-4896-AB6B-835B221F373F}" EventSourceName="Windows Search Service" />
<EventID Qualifiers="16384">1003</EventID>
<Level>4</Level>
<Task>1</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-07-10T03:53:14.000000000Z" />
<EventRecordID>18899</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="ExtraInfo" />
</EventData>
</Event>
Yes, Ive loaded newest bios, drivers,yada,yada,LOL had to go back to earlier drivers as instructed by ati becouse there is a known glitch in newest drivers for windows 7- 64 they said maybe next update LOL. so I thought I would list the events as they happen and I did rebuild the performance counters Thanks
- <System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{B675EC37-BDB6-4648-BC92-F3FDC74D3CA2}" />
<EventID>2</EventID>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2010-07-10T03:53:17.084268100Z" />
<EventRecordID>366</EventRecordID>
<Correlation />
<Execution ProcessID="140" ThreadID="3836" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
- <EventData>
<Data Name="SessionName">Homegroup Log</Data>
<Data Name="FileName" />
<Data Name="ErrorCode">3221225525</Data>
<Data Name="LoggingMode">285212677</Data>
</EventData>
</Event
I'm OLD not as smart as you guy's, but trying LOL!!!
Download and runt memtest and see if it generates any errors. Could be bad memory.
Like the others have said, run a memory test.
Or,even, run Windows Memory Diagnostic.
Check device manager, see if you have device causing trouble.
Run a couple of good A\V programs.
Malwarebytes
Superantispyware
or others.
Turn off hibernate, dis-able USB power saving( in the advance power options ), try disabling sleeping, dis-connect any not needed hardware for a while to see, run msconfig to see if any programs are running in the back ground that you do not need. If you are running Norton A\V(especially an older version) try turning it off and use something else. Un-install any software that is not needed.
Open a administrator command prompt an run "sfc /scannow" (without the quotes and a space between the c and /) to check the system files.
Check your temps while running a stress test (Prime95 or something):
Realtemp
GPUz
Coretemp
HWinfo32
HWMonitor
If your system gets a BSOD, post the error code info that comes up on the screen.
You have a nice system listed in your system specs. Did you build it?
The thing should be able to run just about anything thrown at it.
Sorta at a loss for a fix, 'cause, it could be hardware, drivers, or incompatibilities(conflicts) in one\both. Could be that 12 gigs of memory. Anything. Need a little more info.
I am not real familiar with the platform and memory combination you are using, but this may be of help; it is an answer from G.Skill to a customer in a newegg review.
here's the newest one Thanks again
roblem signature
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Extra information about the problem
BCCode: 116
BCP1: FFFFFA800A7074E0
BCP2: FFFFF8800418CC48
BCP3: 0000000000000000
BCP4: 0000000000000002
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Bucket ID: X64_0x116_TdrBCR:2_Tdr:2_IMAGE_atikmpag.sys
Server information: 08a341db-ff00-4906-aa55-ba07309b7541
and another
Problem signature
Locale ID: 1033
BCCode: 117
BCP1: FFFFFA800ABA44E0
BCP2: FFFFF88003C9667C
BCP4: 0000000000000000
Service Pack: 0_0
Product: 256_1
Bucket ID: X64_0x117_Tdr:2_IMAGE_atikmpag.sys
Server information: cc618601-4169-46ea-b385-b43eaf27a20b
OH YES< i did memtest 86 for one hour no errors? Thanks again!!
Have you tried different GPU drivers?
Yes, the newest ones have a known glitch so had to go back to old drivers and now every so often it does this?? Sad part is before new download game was very stable.
Have you tried playing another game to see if the issue is appears there as well. This can help narrow down if it is a system issue or the game's issue. Reply back with results.
Other than that, try double checking all your connections for power plugs, make sure your RAM and GPU's are all seated well in their respective slots. Also make sure the PSU's fan is coming on when the system usage goes up.
Ok, try this;
Update your DirectX.
And, this:
Run with half your ram and\or run the ram at 1333 and\or bump the voltage of the ram.
How is your ram set-up? Are all the slots filled?
EDIT: Also, again, open a administrative command prompt and run this command: sfc /scannow (make sure to include a space between the c and /.)
I'm running direct x 11 and the ram is at 1033 already I did reload my logitech drivers and played for an hour and then got "java platform se binary has stopped working now" I did just update java today ?? but the game did not fail, It gave me the option to close java and I finished the game ??
Good, I am glad that you got it running to your satisfaction.
Good luck to you and have a good day.
Thanks
Thanks, To all that have been helping me,:toast::toast: I'll keep my fingers crossed.
