need voltage information for a so-dimm ddr3 ram module
797 (0.16/day)
UT,US
System Name Asrock 2012
Processor FX 8350 4.2Ghz no turbo
Motherboard ASRock 970 PRO3 AM3+
Cooling Corsair H70 for CPU
Memory 32GB DDR3 1960Mhz
Video Card(s) NVIDIA 1080 with stock fan
Storage 1TB GIGABYTE SSD NVME PCIE 2.0 + Samsung SSD Evo 850 250GB with Ubuntu + Samsung SSD 860 500GB win7
Display(s) LG HDR 31.5"
Case Big Black Tower
Audio Device(s) Realtek audio + Audigy 2 ZS platinum
Power Supply CORSAIR RM850X
Mouse microsoft intellimouse usb to ps/2
Keyboard Logitech
Benchmark Scores +
3,107 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
1.5V
two sources:
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
all DDR3L can run at 1.5V safely, anyway
That sticker says PC3 and not PC3L, so its regular 1.5v stuff
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
although the official spec site says it's 1.35v somewhere??? what about that, what does it means?
Mussels
58,412 (7.78/day)
Oystralia
If it is DDR3L, then it can run at 1.35V or 1.5V
DDR3L was used in laptops to make the battery life longer, but was always compatible with regular DDR3 voltages
1,533 (0.38/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
D3L is identical to D3 aside from the voltage and there were basically no ICs that were made for only D3L voltages and not normal D3 voltages
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
okey good info. My question will now be are these rams 1.5v only? I have 4 of these 4gb modulos.
Mussels
58,412 (7.78/day)
Oystralia
those barcodes cover the actual labels with the info you're looking for
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
under that label was just the ramaxel name with the model number which I already I knew. I put it up for sale as dual voltage not ultra low but low voltage.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
for what its worth because it likely very different; i had a pair of corsair low power ddr3 that was specc'ed at 1.3v it seemed to me the only difference was one of the two 1600 XMP profiles was 1.3v while the other was 1.5v with speed and timings the same.
i'm sure if you had a machine to boot up and look in the bios would clear things up. but i doubt just going with 1.5v is an issue, ran the ones i had no problemo.
797 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
I'm worro that if they're only 1.5 they won't run on a laptop that takes 1.35 only
1,065 (0.28/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
yeah, no, i really meant to say its safer to stick w/1.5v even if they can do 1.3v. if anything, you're erroring on the side of caution.
