new Aorus build no post
madcattog
5 (0.00/day)
Building new Rig I have ;
Aorus X570 Pro WiFi (Rev. 1.0)
Gold Key Memory 2 x 4Gig
AMD Ryzen 7 3700x 3rd. Gen CPU
GE Force RTX Strix graphics card
750W psu corsair
I put it all together and went to start it up and nothing no post no noises at all signs of life 0. Found bent pin on cpu changed it out and still the same no post. With both cpu's the cpu MOBO indicator LED was lit. through some advice I was told to replace the MOBO. So I did and still he same dilemma. I've read several post saying to flash the bios. I found the bios for my board F11 is the version loaded it on the flash drive placed it inside the bios USB. The Qflash Plus LED doesn't flash when the unit is powered. Mind you the MOBO is in the chassis. I have seen one or two posts in here talking the same problem, but I never saw a resolution. Help New builder.
44,273 (6.80/day)
Pull the board, the ram I would go with a reputable brand such as GSkill, Crucial, Patriot, Mushkin, Adata, Geil, Teamgroup (make sure ryzen compatible)
3,426 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Cooling Stock Intel Cooler
Video Card(s) Dell RTX 3080
Display(s) LG 32" 1440p
Case Phanteks Evolve itx
I agree with eid.
I've seen in the past bad memory will cause system not to post.
Try powering it outside the case. And if you can, different sticks of ram.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
I agree with eid.
Indeed, Start with one stick of ram , then the other , one might be dead , it won't boot with a dead stick either.
FreedomEclipse
~Technological Technocrat~
24,780 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
I would rip it all out and do a dry build to make sure it works before further diagnosis- you can trip the contacts with a screwdriver to get the pc started up.
That way it rules out that your mobo hasnt become earthed with the case because thats what usually happens. One of the motherboard standoffs makes undesired contact with the motherboard which leads to power being earthed so it wont start up.
If it doesnt start up outside of the case then something else is wrong but for me this is the next thing i do after checking all the connections.
madcattog
5 (0.00/day)
Thanks for the responses guys. Pulled out the Mobo, and tested ram and no ram. This is the second Mobo , and CPU. The LED marked CPU is still lit when PSU is turned on.
Still hasn't posted.
FreedomEclipse
24,780 (3.76/day)
After checking the manufacturers website you might need a bios update before you can use that board with the 3700X. Website states F3 Bios version. I dont know that version arrived on your board
Ruru
S.T.A.R.S.
13,772 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
X570 is "made for" 3gen so I doubt that it would need a bios update..
e: And every CPU needs the F3 version so I guess it's the initial version. APUs need F10.
869 (0.42/day)
System Name StriX3D
Processor 9800x3D
Motherboard x870e Strix
Cooling LT720 + Phanteks T30
Memory 32GB 6200 C30 ~62ns
Video Card(s) RTX 5090 Astral
Storage 990 PRO 4TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply 1200W
Mouse G502 X Plus
Keyboard K95 Platinum
It supports 3700x out of the box, like all x570 boards
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
I've never heard of that brand of Ram, borrow a know good brand and try that.
Some motherboards let you flash the BIOS without a CPU or Ram in place, check your manual.
7,487 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
It's not a bios issue plus the Aorus X570 Pro WiFi lacks the bios flashback button for Q-Flash which is Gigabyte's version of bios flashback.
I am with @eidairaman1 on this one it's properly because the "Gold Key" ram isn't Ryzen compatible even't that might not be the issue could be with these unknown brands they are target Intel or AMD and not both.
I am using non-certified ram with my Ryzen 9 3900X and I don't have ram issues.
869 (0.42/day)
System Name StriX3D
Processor 9800x3D
Storage 990 PRO 4TB
Power Supply 1200W
Mouse G502 X Plus
Well, it could be CPU as well. Bent pins are generally speaking not a sign that all is well.. red led CPU indication and all
8,246 (2.09/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
have you tried installing the GPU in the other gpu slot?
Ruru
S.T.A.R.S.
13,772 (3.05/day)
Jyväskylä, Finland
You have to force the CPU into the socket if it has bent pins. I doubt that OP has done that.
3,426 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Unless there are pins missing.
Bent pins could also be a sign of maybe more pins being problematic. CPU must have been handled rather poorly in first place to get a bent pin.
OP, please inspect the CPU and all its pins.
Anyway, best to do is the following (and yes, it is a repeat but sometimes its best to make it short and sweet, right? And this is what I would do):
- Test system outside of the case - as there may be a short
- Test the RAM - Try a single stick in different slots. Then try other stick. Or test with a known working stick.
- Test the Motherboard - This is harder but if you got a spare motherboard or know someone who does then plug all assets in other motherboard.
- Test CPU - try a known working CPU or try the CPU in a known working motherboard.
- Test GPU by trying in different slots or a known working GPU (I got spare old GPUS like Quadro K2000 as example. Sometimes great to hold onto old equipment).
- I would also check with another PSU if you can.
It is one of these issues. If it is more than one item with an issue then that is bad luck and could be damage due to power issues. But that is me just grossly speculating based upon if all these tested and it doesnt work.
One of these parts are not working. You can only do the best you can do by testing what you can. In this case, my bet is either the Ram or the CPU. If you do not have the spare parts, its best to bring it to someone you either know who does have the parts that are known to work and test with you or a company that can do it.
Edit: I see you tested with a different Motherboard and CPU. I am not sure what exactly you tried but if you are using other components but same RAM and it doesnt work, then that clearly points to the RAM. I know Ryzen was fickle with RAM in the past, dont know exactly about 3000 series but its probably still picky.
431 (0.11/day)
System Name Blackbelt 2
Motherboard ASUS M5A99FX PRO R 2.0
Cooling Cooler Master Hyper TX3 evo
Memory 8GB Corsair Value Select DDR3
Video Card(s) ASUS R7260X DC2OC 2GB
Storage INTEL 530 series SSD 120 GB, Seagate Barracuda 1 TB 7200 RPM
Display(s) DELL ST 2240L
Case Cooler Master Elite 311
Power Supply CORSAIR VS Series 550W
Software Windows 7 Ultimate 64 Bit
Benchmark Scores 3DMark 11 6532
I had a similar experience with a ryzen 3 1200 system...the psu wire for the 8 pin cpu power connector had become twisted and kinked causing a no boot scenario.......had to test the psu with a psu tester to determine the problem..
19,379 (3.46/day)
I'd look at the ram or CPU as well.
Also, if this is going to be a gaming machine, you'll want 2x8gb of ram. 2x4gb would be considered a bare minimum and can struggle in some games out of the box. Maybe get 2x8gb off the mobo qvl list and see if that works. If not, rma the CPU if bread boarding it doesn't work.
madcattog
5 (0.00/day)
My aoris has the Qflash plus button and an LED I've tried posting without the ram.
I can only fit it into the top GPU slot my he force won't fit in the next one because of the HD rack
The ram and GPU were both from my old tower and worked fine in that one. I've tried testa without ram or GPU, but the CPU was in for all those tests.
I have the the 28 pin bundle.
When I replaced it with a new Cpu I checked the pins.
3,426 (0.48/day)
Canada
System Name PCGR
Processor 12400f
It won't post without ram either.
44,273 (6.80/day)
Check the cmos jumper, make sure it is not set to erase.
Ruru
S.T.A.R.S.
13,772 (3.05/day)
Jyväskylä, Finland
There isn't one on that board what I looked from pictures. And isn't that a non-existing thing in modern motherboards?
14,545 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
The majority have the clear CMOS button, or reset CMOS.
Ruru
S.T.A.R.S.
13,772 (3.05/day)
Jyväskylä, Finland
Exactly, that's what I've had in the last few boards I've had. Though I prefer the good ol' battery removal for clearing CMOS settings. :)
44,273 (6.80/day)
Ive never known an ATX board to not have clr cmos jumper pins
madcattog
5 (0.00/day)
Next to the words for cmos is a set of pins to short. This is on mine
