New RTX 3070ti - Textures/Flicker/Morphing/Render Issues?
localhost
10 (0.01/day)
Specs (everything stock):
- 12900K
- Asus Strix Z690F motherboard (bios 0403)
- Asus ROG Strix OC RTX 3070ti (latest vbios)
- DDR5 @ 4800mhz (CL40)
- Samsung 980 Pro NvMe
- Corsair 1000W multi rail psu
- 144hz Zowie Monitor (1080p)
I have been testing my new build and have been experiencing graphical issues in all tests done so far. Some more noticeable than others.
COD Warzone:
- While in the plane or when I parachute out the textures like trees, grass and ground will render slowly until I get close to them. Also when walking around on foot I can make grass textures and objects pop in and pop out by walking towards them and walking away from them.
- When looking at far distant trees with a snipers optical zoom the shadows of the trees are fuzzing (similar to white noise) and flickering.
- Sometimes will trigger gpu thermal throttle limits at low temperatures (60-68C). Could be a bug.
- When benchmarking I will get okay average framerates. But I notice something wrong with my 1% lows and 0.1% lows as I’m getting very low values:
Average frames = 160 fps
1% low frames = 50 fps
0.1% low frames = 4 fps
CSGO:
- Walking around I can minimally notice wall and box textures moving. Also shadows seem to be moving and morphing as I am going towards and away from them.
- At a certain period of time I have noticed some players will randomly jitter/lag when they are peeking, moving or jumping.
Heaven Benchmark:
- During the benchmark I can minimally see textures lighting or shadows flicker.
- When in free to roam mode I can see the grass pop in and pop out if I zoom in and zoom out with the camera.
- Also notice some micro-stutters.
- 1% lows and 0.1% lows framerates are very low most the time seeing 1 digit values.
Things I have tried doing with no improvements are:
- Reseating the graphics card again
- Checking temperatures and link speeds
- Changed DisplayPort to HDMI cable
- Used DDU and re-installed NVIDIA drivers
- Updated to latest NVIDIA drivers
- Used older version of NVIDIA drivers
- Tried all different NV Control settings
- Checked if DDR5 ram is detected and running at stock speeds
- Tried turning off in game AA settings in Warzone but issues still happen
I am certain that the problem is not from the application itself. As I never had problems like this with my old build.
Has anyone experienced something similar or know what is wrong and how to fix this issue? I need to confirm the cause because if it’s hardware related I need to start returning it asap. Very disappointed considering the amount of money spent on this build alone.
note: I will upload some gpu-z and hwinfo screenshots when I jump on my computer in case it helps in finding out the problem.
Try the GPU in another PC if you can. It sounds like one of the memory IC's on the card is going bad.
I would of reinstalled all of the windows software the drivers require.
Then try reinstalling the cards drivers again. Hopefully this is a software issue.
With the card throttling you could try replacing the TIM.
Good Luck :toast:
