- Feb 24, 2015
- 6 (0.00/day)
- France
System Name | Protokille |
Processor | i7 4790k 4,4Ghz |
Motherboard | MSI Gaming 5 |
Cooling | Cooler Master nepton 280L |
Memory | 16 Go Kingston HyperX Beast 1600Mhz |
Video Card(s) | Gigabyte GTX 980 Ti 1540Mhz |
Storage | SSD PNY 240Go - Western Digital green 3To - Barracuda 1To |
Display(s) | Asus rog swift pg278q 1440p 144Hz 27" |
Case | Cooler Master HAF X |
Power Supply | Corsair CS750M |
Software | Win 7 64 bits |
Hi everyone i would need your help on this one as i've already built a few units but can't figure out the issue on this one.
As the title say i just can't access the BIOS to insall W10 since i've no image
Specs are
-i5 10400F
-Asus Prime Z490-P
-2x8go 3200mhz
-RTX 3060
So i'll help a lot since i've already tested the PSU the GPU and the RAM in my own build, they all work fine, tried to swap mine into the failling build and still no boot
As i said there is no beeping error when i try to boot, only time it does is when i remove all the RAM sticks, but even if i remove the CPU and keep the RAM there is no beep.
I tried all of this without unnecessary hardwares, keeping only the GPU CPU RAM, no SSD no fans (keeping the CPU fan ofc)
Also i tried it out of the case on a plastic cover so there can be no shorts.
And yes i everything is plugged in correctly i've tried this at least 10 times and got it working first try in my main PC.
I really suspect either the CPU or MB to be dead and ordered new parts to test it but would like your take on it
Thank yuo
Specs are
-i5 10400F
-Asus Prime Z490-P
-2x8go 3200mhz
-RTX 3060
Thank yuo
