- Jan 18, 2012
- 751 (0.15/day)
System Name | My PC |
Processor | i7 4790k @4.4ghz |
Motherboard | Gigabyte z97m-d3h |
Cooling | Corsair H105 |
Memory | 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T |
Video Card(s) | GTX970 Stric oc |
Storage | Samsung 840Pro 512GB |
Display(s) | Asus ROG SWIFT |
Case | Lian Li 359 |
Audio Device(s) | Denon DA-300USB / Denon AH-D5000 |
Power Supply | Corsair AX860 |
Mouse | Roccat Kone Pure Optical |
Keyboard | Corsair K70 |
Software | Win10 64-bit home |
I got a gtx970 with the GSync monitor Asus PG278Q.
In the last months nVidia changed the way GSync works and now VSync and GSync are different options, so we do not need to use VSync when GSync is enabled, as long as we manually cap the frame rate to just under 144fps so that the monitor's GSync system works.
So in the last few months im trying to disable VSync in the nVidia control panel. That works. Until I restart the computer.... this particular option resets... everything else i've changed in the control panel is saved normally and permanently.
Anybody knows how to save this option permanently without manually disabling it every time i restart the PC... its quite an important thing when playing CS:GO...
Thanks in advance for any answers
