- Oct 9, 2007
- 47,741 (7.42/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
OCZ Technology Group, Inc., a leading provider of high-performance solid-state drives (SSDs) and memory modules for computing devices and systems, has unveiled a proprietary interface called "High-Speed Data Link" (HSDL) to accelerate the progression of solid-state storage. Unsatisfied with existing interface options, OCZ developed HSDL to eliminate I/O bottlenecks and enable SSD technology to operate at its full potential. With this initiative, OCZ aims to enhance high performance computing (HPC) and I/O-intensive infrastructures for its clients.
"Solid State Drive throughput speeds are increasing at a rate in excess of what current storage buses can support, and as a result, storage protocols are quickly becoming the bottleneck to storage subsystem performance," said Ryan Petersen, CEO of OCZ Technology. "Designed for both high-performance computing and enterprise storage applications, our new High Speed Data Link interface addresses this issue and revolutionizes data storage by significantly outperforming other current interfaces delivering performance at levels that saturate most CPU buses."
Capable of running up to 20 Gbps of data bandwidth per channel, HSDL significantly outperforms existing storage interfaces such as Serial ATA (SATA) and Serial Attached SCSI (SAS) which only offer 3 Gbps / 6 Gbps data rates. Furthermore, multiple HSDL channels can be combined for maximum bandwidth to increase productivity levels in both consumer and enterprise applications.
OCZ's new HSDL interface is the driving force behind the "OCZ IBIS," an upcoming 3.5-inch SSD to be launched under the new HSDL initiative. As the first solution to make use of the HSDL interface, the OCZ IBIS Series has the potential to redefine storage and surpass the limitations currently placed on hard drives as well as other SSDs.
HSDL is an open standard and allows other devices to leverage this high-speed internal interconnect technology. OCZ is diligently working with platform partners for mass HSDL adoption, and in the meantime, single port adapter cards will ship with every HSDL solid-state drive such as the IBIS Series, while quad port cards for multiple drive configurations will also be available to clients seeking even greater storage and bandwidth.
