Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to TechPowerUp Forums, Guest! Please check out our forum guidelines for info related to our community.
The forums have been upgraded with support for dark mode. By default it will follow the setting on your system/browser. You may override it by scrolling to the end of the page and clicking the gears icon.
ThrottleStop works on anything Core 2 Duo or newer so yes, it will work on a Core i7-720QM.
The 1st Gen Core i processors do not support software CPU voltage control so you cannot use ThrottleStop or any software to change the voltage of these CPUs.
If your motherboard supports it, look for a 920XM on eBay. These Extreme CPUs have an unlocked multiplier and unlocked power limits. A 920XM can run twice as fast when fully loaded compared to the 720QM. Huge performance increase if you can find a way to keep it cool. ThrottleStop can be used to get the most out of an unlocked 920XM.
