Well guys, i need help to overclock my new build... it's not here yet... but i wanna know if it's the same way like my E8400.. i have
GA-EP43-DS3L @ F9A
Intel Core 2 Duo E8400 3GHz @ 3.6GHz w/ Superflower SF-901 + ArticSilver5
2x 2GB Kingston DDR2 800Mhz KVR800D2N6/2G 1.9V [5-5-5-15] w/ Heatsinks
Corsair 450VX
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: x9
Fine CPU Clock Ratio.....................:0
CPU Frequency ...........................: 3600MHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 400Mhz
PCI Express Frequency (Mhz) .........: 100Mhz
C.I.A.2 .................................:[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 900mV
PCI Express Clock Drive.................: 800mV
CPU Clock Skew (ps)....................: 0
MCH Clock Skew (ps)....................: 0
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 400MHz
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ..............: 800MHz
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time..................5
tRCD ...................................5
tRP .....................................5
tRAS....................................15
Motherboard Voltage Control
Voltage Type: Manual
CPU
CPU Vcore: 1.26850V
MCH Core: 1.200V
DRAM
DRAM Voltage: 1.9V
Advanced Settings
Limit CPUID Max. to 3......................: [Disabled]
No-Execute Memory Protect.............: [Enabled]
CPU Enhanced Halt (C1E).................: [Disabled]
C2/C2E State Support ....................: [Disabled]
x C4/C4E State Support ..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function..........................: [Disabled]
Virtualization Technology..................: [Disabled]
Integrated Peripherals
Legacy USB Storage Detect ..............[Disabled]</pre>
my new build
GA-EP45-DS3P @ F8
Intel Core 2 Quad Q9650 w/ Zalman CNPS-8000 + Artic Silver 5
2x2 Kingston DDR2 800Mhz KVR800D2N6/2G w/ Heatsinks
Corsair 750TX
Well i can choose to stay with 2x2 Kingston DDR2 or get 2x1 Corsair TWIN2X2048-6400C5DHX, but for gaming with vista x64 ultimate only 2gb isn't enough right?
About the OVERCLOCK can i use the same options for 3.6 and just try to find the right "Vcore" or it'll be different this time?? My E8400 is perfectly stable with these options... i've ran many tests as possible with Prime95 - 24h... Orthos - 20h... Super PI... etc... and i'm using for 5-6 months already up 24/7 without any problems at all
Complete Config:
Gigabyte GA-EP45-DS3P @ F8
2x 2GB Kingston DDR2 800Mhz KVR800D2N6/2G 1.9V (5-5-5-15) w/ Heatsinks
3x 500GB Samsung SATAII + 2x 750GB Samsung SATAII (Thinking about RAID 0 with 2 500GB Samsung this time)
Pioneer 216D SATA
PowerColor HD4850 PCS+ 1GB/256bits GDDR3 700/1960 (Future CFx with HD4870X2+HD4850)
Case: Elegance (3x 120mm fan 3x 80mm fan)
Display: Samsung LCD LN40A550 1920x1080@60Hz
Razer DeathAdder 3G
Microsoft Wired Keyboard 500
Microsoft Lifechat VX-3000
Zalman ZM-MFC1 Fan Controller
HP PSC 1315 All-in-One
NoBreak APC 1500VA
Powered By Corsair 750TX
I just want a stable 3.6GHz to keep up 24/7 without any problems...
I would be very thankful for any help
and sorry for my bad english
GA-EP43-DS3L @ F9A
Corsair 450VX
Clock Chip Control
CPU
CPU Vcore: 1.26850V
MCH Core: 1.200V
DRAM
DRAM Voltage: 1.9V
Advanced Settings
my new build
GA-EP45-DS3P @ F8
Corsair 750TX
Complete Config:
Pioneer 216D SATA
Razer DeathAdder 3G
NoBreak APC 1500VA
