P8Z77 - V Boot Device LED Problem
kykymonstar
6 (0.00/day)
So I just bought a bunch of computer parts to throw together for a friend, but I ran into an issue when finally trying to turn it on...
The motherboard goes through its standard system check up and when it hits the last light on the motherboard, the "boot_device_LED", it beeps five times and stays constant. There is no visual on the monitor to help me out here, the only thing I have to go off of is the beeps and the light.
I've made sure everything is connected properly and I've kinda ran into a wall here trying to get this work. Does anyone have any ideas? thanks a guys.
Processor: i5-3550 lga1155 3.30GHz
Mobo: Asus P8Z77-V
Video Card: EVGA GTX 480
Ram: Corsair 8GB 1600MHz (2x4gb)
HHD: Western Digital wd10eurx
40,435 (6.57/day)
Recheck all wire connections, reseat all cards, reseat ram, reset CMOS First.
Mobo: Asus P8Z77-V
DOM
7,628 (1.16/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
kykymonstar
6 (0.00/day)
Is there a difference for the asus motherboards when it comes to the "MemOk!" button and resetting the CMOs?
and my power supply is Aztec 750watts
68 (0.01/day)
Processor i5 2500K@4.7 24/7 (x54/32M PI 1.56v)
Motherboard Asus P8P67 Pro
Cooling Single loop H20
Memory GSkill 8Gb 2133 CL10 (1.575v)
Video Card(s) Evga 570@972/1944/2099 v1.1
Storage C 300 / WD
Display(s) LG 24" 1080P
Case TT Spedo
Audio Device(s) On board
Power Supply Corsair HX850W
Software Win 7X64
Benchmark Scores http://hwbot.org/community/user/coolhand411#Points
clear CMOS/with only your OS attached (HDD or SSD) enter BIOS go to BBS HDD PRIORITY ,set your boot device first,go back to main and make sure it shows first /save /boot OS
kykymonstar
6 (0.00/day)
I would but the problem is that it fails the start up sequence before that happens, and there is no display.
40,435 (6.57/day)
so after you power up the video never comes on?
Get the motherboard manual out and read it.
Also are you sure you have the video cable on the video card or the IGP itself
DOM
7,628 (1.16/day)
TX, USA
Motherboard Asrock
Cooling Water
Software W 10 Pro
try booting with out the gpu and use the igpu
kykymonstar
6 (0.00/day)
I did but Asus doesn't describe what the "boot_device_LED" means and looking it up through google is getting me different scenarios that doesn't relate to me.
I'm not sure what you mean by the video cable.
kykymonstar
6 (0.00/day)
Okay so I took out a ram stick, put the video card in another slot, ANNND resetted my CMOS. Now the display is back up and running. Although, I'm not sure why but it is giving me a "CPU Fan Error!" Even though the fan is clearly running. Why is that??
INSTG8R
Vanguard Beta Tester
7,969 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
You may have the CPU Fan on the wrong header. There are 2 right beside each other. I made the same mistake on a recent build I did for a friend on a Z68Pro/Gen 3. Just put it on the header and that should solve that problem ;)
kykymonstar
6 (0.00/day)
I just checked the wires again and I noticed I put it in the wrong CPU fan, everything is now working perfectly! Thanks for all your help!
