PC connected to UPS, hangs w/o display on battery mode
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
It might be stuck in C1 or C2 state.
When it does this, have you tried pushing the power button? It might pull it out of the stuck power state.
561 (0.11/day)
System Name Salamander | RetroPC
Processor Ryzen 5 3600 @ 4.325ghz 1.206v | Phenom II X4 B60 @ 3.6ghz 1.42v
Motherboard Asrock X370 Taichi | Gigabyte 890GPA-UD3H
Cooling Byski cpu block - Black Ice Nemesis 360GTS XFlow - Arctic P12 A-RGB x 3 | Scythe Kotetsu Mark 3
Memory Team T-Force Xtreem 2x8GB DDR4 3733 @ 3733mhz c16 1.4v | Crucial 2x2GB DDR3 1600mhz c9 1.65v
Video Card(s) XFX RX-470 RS 4GB GDDR5 | MSI Hawk GTX 650ti 1GB GDDR5
Storage XPG SX8200 Pro 1TB | Toshiba 2TB 2.5" | WD Caviar Blue 1TB
Display(s) Xiaomi A27Qi 2560x1440 180hz IPS | Dell P1914S 1280x1024 75hz IPS
Case Fractal Design Define C | Armageddon T5X Pro II
Audio Device(s) onboard | Creative X-Fi Titanium
Power Supply Seasonic Prime Gold 650w | Silverstone Essentials 500w
Mouse Machenike M5 | Razer Deathadder Essentials
Keyboard Steelseries 6GV2 Cherry MX Black | A4Tech KBS-26
Software Windows 11 Pro | Windows XP Professional SP3
Have you gone into the BIOS and changed the power loss setting to "power off?" Default is usually "resume previous." You might be experiencing a conflict between UPS, operating system, and BIOS settings.
I do...
BIOS: power off
OS: disable sleep states, power off monitor with idle time
UPS software: 2 minutes on AC, power off.
UPS tells OS to shutdown after 2 minutes then turn itself off -> BIOS says to stay off. When power is reliably back on, I turn UPS on, then computer on. Computer is none the wiser that there was no power in that period.
I think what might be happening is that your PSU/motherboard thinks it is in a standby power state when power restores and it's not providing enough 12v for the CPU to come out of that power state so it's stuck there until it loses all power resetting the current state.
will check with the bios but aside from that I couldn't do anything else. UPS is pretty basic with no monitoring software.
When it does this, have you tried pushing the power button? It might pull it out of the sleep state.
will give that a try
is it possible it's a power supply issue? May psu has gone through hundreds of power interruptions since I got this 3 years ago. It was only last march that I decided to get a UPS.
OneMoar
There is Always Moar
8,834 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
change it and find out
but a decent psu should not be behaving in this manner it `should` just hard power off when it detects problem with the mains power
561 (0.11/day)
just got another power interruption a few minutes ago, around 2-3 seconds, everything works fine no hang-ups. :banghead:
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
2-3 seconds, the UPS, so long as it has sufficient charge, should be able to just carry the computer through it. Maybe when you have problems, the battery doesn't have enough charge.
561 (0.11/day)
it was fully charged yesterday though when the issue kicked in
OneMoar
8,834 (1.61/day)
Rochester area
O for ffs no not even close try more like 500-900Ms before the caps can't provide enough
its not battery its not not some bios glitch the 'ups' and or psu is crapping out probably the power is got a ton of ripple in it combined with a aging psu
'ups's even crap ones are intelligent they simply will not operate AT ALL if the battery has ANY fault again the outlets on the UPS are not loosing power its NOT turning off its just not providing clean enough power
anykind of dip in voltage below about 104 to 108v and the psu should just switch off if its not its faulty and needs to be replaced
most AVR units the inverter operates FULL time e.g mains power is converted internally to 12 or 24VDC filtered and then transformed back to mains voltage this is how you get sub 50Ms switch times incoming power surges are literally shunted into the battery and ground demand for more amperage/voltage make up comes from the battery because the inverter is always on and shunted via a fast acting relay or the charge circuit just runs all the time and there is a relay that turns that on and off as needed
there is practically no switch time
ups failure is usually down to the battery being bad e.g the ups is dead or to much ripple
hook up a GOOD multimeter and yank the wall power
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
How long was the outage for? Longer outage = more likely to see issue?
And as @OneMoar said, one usually tests UPS first by having nothing powered on and physically removing the plug from the outlet forcing it to the batteries. If it appears to be working fine, plug it back into the mains, turn on your equipment, and try again. If the UPS gives no signs of problems (usually beep codes or simply goes off), it's probably the computer and not the UPS.
A square sine UPS has killed two PSUs in my server. After changing it to pure sine, I haven't lost one. That said, my PSU just wouldn't turn on after turning it off. The behavior you're observing is weird.
Edit: http://www.anandtech.com/show/7950/corsair-rm1000-psu-review/5
However, some components come from manufacturers with a mediocre reputation, such as the CapXon capacitors on the secondary side of the transformer.
Maybe the source of the problem?
13,943 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I think it is an excellent idea to check this setting, but note the default is typically "Always off". This must be changed manually by the user, and is commonly done with remote location systems so the administrator does not have to make a road trip to boot a system after a power outage.
Note that most UPS that do have software and communications have a self-test feature built in. So, for example, if you have PowerChute from APC, you can "Run Self-Test" any time you want without having to pull any plugs or shutdown Windows. Other UPS let you activate a self-test from the front panel of the UPS.
I also have two 150W incandescent lightbulbs. To test my other UPS I connect one or two lamps (depending on the size of the UPS) to the battery side of the UPS, then pull the plug and see what happens.
561 (0.11/day)
update: another power interruption happened around 10 mins ago. Same issue. After I did a hard reboot, i checked the event viewer which I should have done from the start of this issue and I think I may have found the culprit.
so what causes my gpu to randomly hang after a power restore from battery mode?
12,170 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
voltage drop from caps dying in the PSU, most likely from squarewave boiling off electrolite and the reduced hold up time causes issues with the card as it has the shortest/lowest available capacitance to deal with voltage drops and ripple.
Power the machine off, unplug it, press the start button to discharge the PSU and then remove it, if you are brave and careful take it apart and I bet your caps are bulging. Then replace it.
