PC randomly restarts
31 (0.03/day)
System Name BarneyRaptor
Processor 13900KS
Motherboard ASUS Z790 Apex
Cooling Custom; 420x60 & 280x30, Heatkiller 4 Pro, Bykski ram
Memory Gskil 32GB 8000 MT/s
Video Card(s) RTX 3060 TI FE -- x2
Storage Samsung 990 Pro & Sabrent Rocket 4 Plus
Display(s) 4 x 27"
Case Lian Li Lancool 3
Power Supply Corsair Rm850x Shift
Mouse Corsair
Keyboard Razer
My PC randomly restarts. Just now it restarted 2x in a row back to windows desktop. The last time it did it was 2 days ago.
This is my older system but still my primary while i continue to work on my new build. I will switch to my new build now but want to see if i can have this as a reliable back up workstation/tradestation.
I am trying to diagnose this. Is it a hardware or software issue ? It never restarts in windrows recovery environment, just normal desktop.
If it was the PSU would it not just shut down rather than restart? or any piece of hardware for that matter..
I tried removing overclock and then reset cmos. I did some Windows scans and repairs.
My next step might be to do a "In-Place Upgrade" But i thought i would see what the forums say. If i can get any more specific things to troubleshooot consider.
system;
Motherboard- ASrock X79Xtreme6 LGA 2011
CPU- I73930K Sandy
PSU- Seaasonic X650 Gold
SSD- Samsung 870 Evo
Ram-Corsair Vengeance 16gb (4x4gb)
GPU- 3x EVGA Geforce GT-640 2GB 128B
Cooling- Monsoon S2 & SwiftechMCP655-PWM
Alphacool 80mmx120mm rad
XSPC RX120 rad
3 Noctua 140mm
5 120mm Gentle typhoons
NZXT fan controller
@P4-630
April 2013 i Bought the PSU
I got the Samsung SSD in December of 22
Are there any dmp files in LiveKernelReports folder?
No, when PSUs start to fail, they typically exhibit erratic intermittent errors. They don't always just "stop working" or die in a glorious and noisy puff of smoke.
Same with most devices, not just computers.
Your PSU is ten years old. It doesn't owe you anything anymore. Be grateful that you got ten years of faithful service, buy a replacement and move on.
Best of luck.
Best of luck.
so you know for sure it is my PSU and not my Motherboard, ram, cpu, gpu's, ssd's, Windows10 or other software? you are really good
Of course I don't know for sure. No one here does. How could they?
If you don't like my suggestion, feel free to ignore it. That won't necessarily make it wrong though. And you don't need to say it aloud. Keep doing that and eventually no one here will bother to answer your questions.
I hereby bow out of further participation in this discussion. Best wishes to you in solving your conundrum.
i have no problem buying a new psu and trying it. iwas just looking for anyother obvious things i missed. and btw "buy a replacement and move on." sounds like a definitive statement
See if you can borrow a PSU from a friend or let your PC test at a shop with a new PSU.
This is the easiest first step
C:\Windows\LiveKernelReports
Also check Event Viewer for errors when the reboot happened
Remove the 3 gt 640s and try 1 at a time
Okay, Question 1: Why the hell do you run 3x GT640s?
thanks. I will try this first thing when i get this system running again. I switched over to my new build so i could keep working today.
lots of monitors
i will probably pull my shift out of my new build to test PSU, or buy one i can return or keep as a backup
I'd recommend keeping new power supply and keeping old one as a backup if it proves not to be bad.
Hasnt been here since wednesday...
