- Oct 22, 2023
- 313 (0.54/day)
System Name | SYSTEM |
Processor | RYZEN 7 5700X |
Motherboard | TUF B550M GAMING PLUS |
Cooling | AG620 CPU COOLER |
Memory | 16GB RAM DUAL CHANNEL 3200MHZ STOCK |
Video Card(s) | RTX 4070 GIGABYTE 12GB WINDFORCE |
Storage | 1TB HDD 256GB SSD |
Display(s) | LG ULTRAGEAR 144HZ |
Case | AIGO DARK FLASH |
Audio Device(s) | MOTHERBOARD AUDIO |
Power Supply | XPG ADATA PYLON 650W |
Mouse | REDRAGON COBRA M711 V2 |
Software | WINDOWS 11 |
Hello
I have a tuf b550m ( suspected the motherboard previously , i had a msi mpg b550 and it showed the same behavior ) , ryzen 7 5700x3d , 32 gb dual channel 4 slots ( tested with memtest86 ) and a 650w xpg pylon psu ( i had a 4070 windforce before , it worked with the same configs for about 1 year fine , same TV , cables etc... i only got a new 4070 model ( eagle ) and gave my windforce to my brother)
I´m wondering , is it safe to assure my GPU is busted ? it is new and this happens randomly
It is not due to monitor being ON before the PC as it works without turning the monitor on ( monitor and TV works fine as well)
When the PC is on , it works flawlessly , no crashes whatsoever
I´m about to use warranty but i´m wondering if it is really the gpu
the previous gpu worked fine on the same specs
Safe to assure it is my GPU or something else ? but i´m afraid the warranty won´t find the issue
Should i look into something else ?
thanks
thanks
