jcdenton21
- Jan 28, 2006
- 95 (0.01/day)
- Slovakia, KE
Processor | AMD Athlon64 3200+ (2500MHz 1.4V) |
Motherboard | ASUS A8N-E rev. 2.00 |
Cooling | Arctic Cooling Freezer64 Pro, , Thermalright hr-05 SLI |
Memory | 2x1024MB (PQI+GoodRAM) 418MHz |
Video Card(s) | ASUS EAH3650 256MB GDDR3 725/1600 |
Storage | Seagate 120GB SATA ST3120827AS |
Display(s) | 19" Samsung 940BW |
Case | Euroce ML5410 |
Audio Device(s) | integrated in nForce4Ultra |
Power Supply | SeaSonic S-12 380W |
PC starts and runs, display only in standby mode-beep code recognized
hi guys
I would like to ask wheather somebody had ever the same problem as me with PC
my configuration is
MoBo: ASUS A8N-E (rev2.00, bios 1013, 1006 and other- same problem) chipset cooled by Zalman NB47J + 120mm fan blowing onto Zalman
RAM: 2x256MB GoodRAM PC3200 (2-3-2-6 1T also 2.5-4-4-8 2T, same problem)
CPU: AMD Athlon 64 3200+ (default 2000MHz, 2500MHz-same problem) cooled by AC Freezer64 pro
VGA: Sapphire x700 128MB/128bit PCI-e (400/500 also 475/630-same problem) cooled by Zalman VF700 AlCu
tested also with S3 2MB 765 - same problem
HDD Seagate 120GB SATA1 (ST3120827AS)
Case Eurocase ML 5410
PSU Eurocase 400W (+3,3V 30A, +5V 32A, -5V 0,3A, +12V 16A, -12V 0,8A, +5VSB 2A)
Sea Sonic S12-380 (SS-380HT Active PFC) is ordered and I am waiting
and now the problem
I was changing stock cooler on my VGA, then I put VGA into pci-e x16 slot, pc started but no screen on display (it was black and LED was orange, normally it is green)
clear cmos didn´t help
so I unplugged power cable for cca 15 minutes and after that pc started normally with display working
few weeks later I was changing cpu stock cooler an it was the same as before-pc started but display not
clear cmos also didn´t help
unplugging yes
then I was changing that little asus chipset fan and it was same again
I put there my s3 vga and still no screen
I put my X700 into pci-e x4 slot and it worked
then I put X700 into pci-e x16 slot and it worked again and display was working
as I am thinking now I happend only 4 or 5 times and before that I was doing something with HW (changing coolers mostly)
it is prime stable and temperatures are good
If I don´t do anything with HW it works fine (2 month from last cooler changing)
where is the problem
could you help me please
my x700 is maybe 10 months old(less than 1 year)
yeah I´ll wait for psu and then test
problem is that I don´t have speaker in case so I can´t hear beeps
twice it booted with pci vga but once even pci vga didn´t help (then I plugged x700 and it worked fine)
or to be correct
with PCI vga it booted always correct when it was in first PCI slot (in manual it is shared)
damn PSU
it didn´t arrive and they told me that 2 weeks later it might come
hi guys
my configuration is
and now the problem
unplugging yes
or to be correct
damn PSU
