Pci-ex gen detection problem in gpu-z 1.16.0
2 (0.00/day)
System Name My Pc Desktop
Processor Intel Core I5 2500K
Motherboard Gigabyte Z68P-DS3
Cooling standard
Memory 8 GB Corsair Vengeance dual channel
Video Card(s) Kfa2 gtx 1060 OC 6GB
Display(s) Philips 32pfl5625h
Case Cooler Master Centurion 590
Audio Device(s) Hdmi audio
Power Supply Cooler Master 650 Watt
Mouse Logitech Optical
Keyboard Asus Cerberus
Hello to everyone. :-)
There is a problem with gpu-z 1.16.0 when detecting the pci-ex generation of my motherboard (Gigabyte Z68P-DS3).
When I launch the small render to obtain the maximum specs about the pci-ex gen the render starts and in the field "bus interface" it is shown "pci-ex X16 2.0".
My motherboard supports officially the generation 3.
My current gpu is a Kfa2 1060 OC 6GB.
I left the rendering active for 5 minutes but the situation didn't change. By the way, is it safe leaving the rendering on for much time? Or could it be dangerous for the gpu?
Thank you in advance to everyone. ;-)
Welcome to TPU. And just to make it easier, please fill your system specification : https://www.techpowerup.com/forums/account/specs
What processor do you use? Your board might support PCI-E 3.0 but it will still need an Intel 22 nm processors (Ivy Bridge i5 or i7) to use PCI-E 3.0 lane. If you're still using the good old Sandy Bridge then that's the cause of your issue.
System specifications inserted! ;-)
I understand, effectively I have a Core I5 2500K, so this is the real cause of the issue.
But I wondered also about the rendering test ... could it be a problem for the gpu running it for several minutes or is it totally safe?
2000-series SB chips don't use PCI-E 3.0.
http://ark.intel.com/products/52210/Intel-Core-i5-2500K-Processor-6M-Cache-up-to-3_70-GHz
I was wondering the same thing mine shows 1.1 lol with just one gpu
is all the power saving in windows for graphics card and the driver set to maximum performance?
I'll need to check windows and the drivers are set to performance, but can't check till Friday....
and normally this motherboard does not support 3.0.
you need motherboard revision v2.0 or higher
