[WTB] PCI Wireless G/N Adapter
5,202 (0.88/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
Looking for a PCI wireless adapter that is compatible with both wireless N and G. Mom keeps complaining about how hideous things look when guests come over and see cables all over the floor/against the walls. :ohwell:
Keep in mind I'm using this for a router that's located less than 15 feet away so nothing fancy/too expensive!
I may need more than one so if you have two (or more) LMK!
Just to be clear. You want one that is PCI. So PCIe is a no go, right?
I can use one PCI-E adapter, I don't plan on doing Crossfire/SLI on my Gene II anyway. Do you have something I can steal from you sir?
Unfortunately, I do not have one to spare as I have sold the one I owned, but it is on sell for next to nothing.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833180058
Not the best, but provides enough to game very well and you are 10 ft. closer than the distance it was being used and 2 less walls between you and your router I am guessing.
P.S. Sorry, just noticed the WTB tag. I do apologize for posting when I wasn't selling.
Thanks a LOT for the link! I'm going to hop on that if nothing shows up here in 3 days or so, I'm not in a rush. :toast:
Unless you have a awesome internet connection, wireless G is all you need TBH. I have a Gigabyte Aircruiser wireless G with full size and low profile brackets I could sell you for $10 shipped. Great card but I don't use wireless except for spoofing.
i have a pci-e 1x wireles n adaptor. look in my fs thread.
A little out of my price range, thanks though!
The thing is my old Linksys wireless G adapter was not compatible with my Linksys N router so I'm trying to make sure it's compatible. I don't know how this compatibility stuff works so I'm just gonna play it safe, unless I'm told that a certain router is 100% compatible.
Oh and Daed you have a PM coming your way.
:toast:
:toast:
:wtf: Any and all Wireless N Router should be able to connect to Wireless N/G/B at the least. Your wireless G adapter should work just fine. You may want to check the router to be sure you don't have it set to "N Only" network.
That's... interesting. I gotta check that out later today, right now I gotta dash!
No more adapters needed, I'm going to buy Daed's for one comp and see if I can get my old USB adapter to work for the other. :toast:
