Hello,
I just picked up a Surface 7 Pro (i5-1035g4, 8 GB Memory, 256 MB SSD (nvme).
The performance on this tablet is very laggy (to say the least). Its laggy opening apps, watching videos, etc.
Running some benchmarks (PCMARK10) shows dismal performance.
I've tried disabling the "Intel(R) Dynamic Tuning service" to no avail.
I found ThrottleStop hoping it could fix my issue. Unfortunately I am still learning how to use this tool.
I've tried a few things (Enabling "Speed Shift EPP, setting value to 0", Disable SpeedStep, Disable BD PROCHOT)
Nothing I have tried seems to have helped . I know there is more that needs to be configured, I'm just not sure what.
VID = 0.71 to 0.72
The clock speed never goes above 600 Mhz (even when running TSBench). The clock doesnt seem to ramp up very much under load.
Max PKG power never exceeds about 8 Watts.
Under Limit Reasons, when running TSBench, "BD PROCHOT" is yellow under CORE, GPU and RING. "EDP OTHER" is Red under CORE and RING, Yellow under GPU. PL2 is Yellow under CORE.
Under Limit Reasons, at idle, "EDP OTHER" is Red under CORE and RING, Yellow under GPU.
I dont know where to go from here. I Just bought this tablet and I'm so frustrated with it I'm ready to sell it on.
I'm hoping Throttlestop can resolve my issue with this tablet. I'd like to keep the tablet if these performace issues can be resolved
As I said I am new to this application and dont really know what I am doing.
Any help would be appreciated.
Thanks,
Paul
Also, The CPU temperature never goes above 50 Degrees C, even when stress testing. All tests are done with the table plugged in
VID = 0.71 to 0.72
Thanks,
Paul
