Plugging in graphics card while computer is on?
runevirage
80 (0.01/day)
As a point of interest, what would happen if you plugged in the PCIe 2.0 connectors to a graphics card while the computer is on (assuming that there is an onboard GPU or another graphics card already running the OS in normal mode)? Thanks.
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
option A.. nothing happens..
Option B... you blowup the video card AND/OR the motherboard as well.
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
I definitely wouldn't recommend doing that, but i doubt much would happen.
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
if your system is new it will simply freeze, older systems you run a risk of killing a part or all of it. but I have done it not thinking and it simply froze up.
8,519 (1.35/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
Couple things could happen:
A) Power surge to the card and blows the card
B) Power drop from the card could cause unstability to the rest of the powered components.
C) Power supply blows from large power difference.
D) Nothing, card powers on and windows needs a reboot to recognize it.
Wanna try and tell us how it goes?
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
First and foremost you would probably be ridiculed by those who know better and exercise common sense. It can cause several issues as far as your hadware is concerned. Freeze up, blown capacitors, transistors, HDD corruption and other permanent hardware failure. I've accidentally done it with RAM before and nothing bad happened.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
As a point of interest, what is so important you cant wait the extra 2-3 minutes to shut it down and reboot. Its going to need the reboot anyways to work.
AltecV1
1,286 (0.22/day)
Republic of Estonia
Processor C2D E8400@3.6 ghz
Motherboard ASUS P5KPL-AM
Cooling Freezer 7 pro
Memory Kingston 4GB 800Mhz cl6
Video Card(s) Sapphire HD4850 700/1000 + Accelero S1 Rev. 2
Storage WD 250 GB AAKS
Display(s) 22" Samsung SyncMaster 226BW
Audio Device(s) int.
Power Supply Forton Blue Storm II 500W
Software Windows 7 64bit Ultimate
your computer would froze and thats it
DaMulta
My stars went supernova
16,168 (2.36/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
It would power up, and if you go into device manager you can turn it on.
I have plugged in cards/removed cards while the machine is on a TON of times.
I use to flip people out in the old server room when I would pull/plug in cards without shutting down.
Of course you are going to have to have another card ON and plugged in while you do it.
wolf
Better Than Native
8,676 (1.32/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
Nothing good will come of this, possibly nothing bad either, but definitely nothing good.
but hey, theres only two ways to find out :)
streetfighter 2
1,655 (0.31/day)
Philly
Umm... I'm going to agree with what just about everyone said.
If you still want to try it though, for the love god get some eye protection because you'll need to read our posts making fun of you *if* it explodes.
3,059 (0.43/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
i bet it would be fine if i had an extra psu around id try it on the p5n-sli with an x800 and an x300
hat
Enthusiast
21,754 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Well, certianly nothing BETTER then doing it the old fashioned way can happen.
5,202 (0.89/day)
System Name Dust Collector
Processor AMD Ryzen 5 3600X
Motherboard Asus B550I Aorus Pro WiFi AX
Cooling Alpenfohn Black Ridge V2 w/ Noctua NF-A9x14
Memory Corsair Vengeance LPX 16GB DDR4 3200MHz/CL16
Video Card(s) Power Color Red Dragon RX 5700 XT
Storage Samsung EVO+ 500GB NVMe
Display(s) Dell S2721DGF
Case Dan Case A4
Power Supply Corsair SF600 Platinum
Mouse Logitech G603
Keyboard Logitech G613
I tried it with RAM and my computer froze just like erocker's did. Never had the balls to try a GPU though... you go first.
1,258 (0.20/day)
North Carolina
I've done it before and this happened.
It was an old Dell P4 machine and the card was an AGP MX 4000. I didn't realize the machine was on :)shadedshu) and I put the card in the AGP slot. There was a big spark/noise from the PSU and it turned off. Didn't come back on. Got a new PSU and the machine worked fine, including the graphics card.
runevirage
80 (0.01/day)
Ok guys, well I tried it. And....
Nothing really happened other than the fan on the card went up to 100%. The card wasn't recognized in the control panel, Realtemp, or GPUZ. The fan speed went up to 100% even with only one PCIe power connector in, even though it normally requires two.
The fan speed thing was kind of interesting, why would it default to 100% upon power initiation? Possibly to prevent overheating?
1,258 (0.20/day)
North Carolina
Most cards run the fan at 100% at boot then it quietens down. No idea why.
But more importantly,
YOU TRIED THIS??? Such a terrible terrible terrible idea. You could have lost several hundred dollars worth of gear in a second. Even if you were curious, that was a dumb thing to try.
:shadedshu :shadedshu :shadedshu
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
So you scanned for new hardware in device manager?
8,519 (1.35/day)
Kansas City
Processor 9800x3D
Software Win 10 64x
Well at start up the fan ramps up until the OS can tell it to cool down. Since the OS doesn't recognize the card it can't tell it to chill.
1,639 (0.29/day)
I'm roomates with Corey Feldman
Processor W3520 Xeon
Motherboard Asus Sabertooth X58
Cooling Cool it Vantage
Memory 6gb Dominators
Video Card(s) GTX 460
Storage 60Gb Vertex II 500Gb storage
Display(s) LG 42LH40 42" 1080P
Case 932 HAF
Audio Device(s) Voices in my head
Power Supply Raidmax730/
Software Win7Pro64
Benchmark Scores Pretty High one's. but it's not a contest/ I just read them for the articles.
3volvedcombat
1,514 (0.26/day)
South California, The desert.
System Name My Computer
Processor Core 2 Q9550 4Ghz 1.23volts
Cooling Corsair
Memory OCZ
Video Card(s) Galaxy
Storage Western Digital
Display(s) Acer
Case Lian li
Audio Device(s) Asus
Power Supply Corsiar
Software Microsoft
Benchmark Scores 25,000 3dmark06 at 4.35Ghz processor, 835core card!
Do it again, looks like you need to, go right click on computer.
then select MANAGE.
Find device manager
Then go down to vga section, youll see the card, press activate, or enable, or turn on, because its disabled, and you should be fine! :toast:
DaMulta
16,168 (2.36/day)
Oklahoma T-Town
Storage SSD 64GB
PEOPLE in this thread need to grow some balls lol
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
setup your video camera, point it at your pc, turn on pc, plug in pci-e card. report back.
Perseid
154 (0.03/day)
Wisconsin, USA
Processor i7-870
Motherboard ASUS P7P55D-E Pro
Cooling Coolermaster Hyper 212
Memory 2x OCZ Special Ops 2GB DDR3 1600 (PC3 12800) 8-8-8-24
Video Card(s) Palit GTX 470
Storage Numerous 1.5 and 2 TB
Display(s) HP w2338h
Case NZXT Lexa S
Power Supply CORSAIR TX Series 950W
Software Windows 7
There are actually people suggesting someone DO this? Whiskey Tango Foxtrot? Seriously. Think of how much power modern video cards use. Think of a new device suddenly asking for that power out of the blue. Now imagine the power suddenly shooting through some pins when other pins aren't connected yet because you didn't seat it 100%.
runevirage
80 (0.01/day)
Damn, you guys are right, I should've tried to detect it through device manager. I guess at the time I was just too excited. Plus the 100% fans thing was freaking me out.
As to why I tried it? Some people live for danger :cool:
Would try it again but my hands are still bruised from the last try. Damn PCIe 2.0 power connectors are so freaking hard to get out you practically need a pair of pliers. Anyway, might do this again some time, on another rainy night perhaps...
And as everyone has noted in the thread, this WAS a stupid thing to do, and I don't recommend that anyone else do it lol.
