Port Forwading and static IP help.
JC316
Knows what makes you tick
9,397 (1.32/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
OK, I have a bunch of cool online games, but half of them don't work. Starcraft is the latest casuality of this situation.
I need to forward port 6112 on the udp and tcp. In order to do that with my router I need a static IP. I have found a site called www.portforward.com that kinda explains this, but I still cant make it work.
Does anyone know how in the hell I am supposed to do this?
My router is a Linksys WRT54G and I use a wireless ISP, so no modems.
Thanks Alec. Thats one step. That part I could basicly figure out. It's this static IP thats kicking my ass. I need one to make the port forwarding work. Otherwise my router will just assign a new one and I will be screwed.
Need a static IP? Just go to network settings / general / internet protocol and DESELECT obtain IP automatically, and set your own IP here.
ALTERNATIVELY... use your router interface to set a static IP address based on the MAC address of your PC's network card.
Here's a picture from my router (Netgear). There is a "database" of attached devices. I select one, click edit, and assign STATIC rather than DYNAMIC IP. I'm sure linksys has something similar. If not... get yourself a cheap Netgear Pro Safe, e.g. FVG124G, FVG318, FVL328 etc. You can pick them up for $20-$50 on ebay (new) and they all have this feature.
I think the man's right... I just messed w/ mine (bridging it to my DSL modem around 3 days ago) & iirc, it has options for STATIC IP, you set in the router itself.
IIRC, it's around the SAME SPOT in a LinkSys that doing MAC CLONING is in... check it yourself, & GOOD LUCK!
APK
P.S.=> Windows will also let you do that, in its ALTERNATE CONFIGURATION for Tcp/IP settings, & MIGHT be something to look @ also... apk
As long as the PC behind the router has a static IP then there is no problem. The external IP (ie the Routers) changes about once a week on my router, and I have no port forwarding issues. All my online games work perfectly :)
Love this stuff... this thread made my bookmarks/favs for messing w/ my LinkSys BEFSX41 unit here!
* I don't mess around as much as I used to w/ routers, hubs, hardware firewalling, etc. anymore, so I need decent references... Darknova & CompletelyBonkers - you 'set the trend' for this thread & 'made it worthy' imo, lol, no joke!
APK
yeah I'd say the easiest and most reliable way to keep your IP address static is to go into the linksys settings and choose have it assign a specific address to your computer's mac address. Then even if you use more than one OS or if your system needs to be reinstalled down the road, or for whatever reason- you wont have to go back into windows and reconfigure it, once it's set, it's set...
