de.das.dude
Pro Indian Modder
- Jun 13, 2010
- 9,251 (1.70/day)
- Internet is borked, please help.
System Name | Monke | Work Thinkpad | Old Monke |
Processor | Ryzen 5600X | Ryzen 5500U | FX8320 |
Motherboard | ASRock B550 Extreme4 | ? | Asrock 990FX Extreme 4 |
Cooling | 240mm Rad | Not needed | hyper 212 EVO |
Memory | 2x16GB DDR4 3600 Corsair RGB | 16 GB DDR4 3600 | 16GB DDR3 1600 |
Video Card(s) | Sapphire Pulse RX6700XT 12GB | Vega 8 | Sapphire Pulse RX580 8GB |
Storage | Samsung 980 nvme (Primary) | some samsung SSD |
Display(s) | Dell 2723DS | Some 14" 1080p 98%sRGB IPS | Dell 2240L |
Case | Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB |
Audio Device(s) | Logitech Z333 | Jabra corpo stuff | Some USB speakers |
Power Supply | Corsair RM750e | not needed | Corsair GS 600 |
Mouse | Logitech G400 | nipple | Dell |
Keyboard | Logitech G213 | stock kb is awesome | Logitech K230 |
VR HMD | ;_; |
Software | Windows 10 Professional x3 |
Benchmark Scores | There are no marks on my bench |
This is a very general way to replace the power button on a pc case.
A lot of weird problems can be attributed to a faulty power button.
same goes for the reset button.
You will need:-
**CAUTION!**.. some sense of tinkering and electronics knowledge is reqd. Do at your own risk.
Identifying the fault.
Its pretty simple. Get a multimeter. Set it to resistance
Take the two points of the multimeter, touch them to each point on the power connector female jack from the case. there should be open areas on the outside of the jack with metal contacts to test, making it easy for us.
now if the power button is not being pressed and the meter reads anything other than infinite resistance, the leads are being shorted and your power button is done for. If it was the other form of failure, that is the leads were not contacting, it would simply not power on the PC at all.
Reason for failure
Repeated usage, and dirt can get in. contacts are very close, and as you will soon discover, these switches actually have two modes of operation.
Fixing the problem
First you will need to get access to the button in question. That usually means taking the front bezel-off. Be sure to disconnect all the front panel connections before you attempt to remove the panel.
Sometimes the buttons and indicator cluster is a separate unit on some cases. this makes it easier, as you can just unbolt this off of the case and work on it. (or harder if the bolts are really hard to reach)
In my case, i had to loosen off the front bezel. Then unscrew the unit apart. Then unscrew the final bolts holding the unit together.
What you should be left with is the hidden wiring connecting the push button switches.
sometimes good manufacturers hot glue around the pins to make it more rigid, and the front i/o cables more "yank"-able.
Flip over the correct side of the unit to check one last time that you are about to vandalize the bad button not the other one..
Then using a sharpie, slowly remove the hot glue, bit by bit with the sharpie. taking care not to cause to much damage to the case components. just remove enough hot glue so that the clips holding the switch become free.
Using the needle nose pliers and your "correct" hand, grap the faulty switch and give a small pull on it. It wont come out as the clips are still holding it. Dont pull it too hard and you will break the clips and make the whole thing useless(you will have to permanently superglue your news switch, no more repairs).
With your other hand, press down on the panel, and use the flat head screw driver to ease of the clips. The switch should now be out.
Cut off the wires from the faulty button. Strip, sand and solder the tips of the bare wires, making it ready for soldering.
Since you are in so "deep" already, might as well remove the plastic superficial switch and give it a clean. usually sweat comes here, and attracts dirt which makes it a bit "sticky". removal should be similar to the actual switch, i.e. more clips
Use cotton swabs and rubbing alcohol to clean the surface. Can apply petroleum jelly for lube, leave it at that. Important information for a later step is given in the pictures. Concentrate!
Understanding the pinout on the switch.
There are 6 pins, two rows, three on each side.
Pins on the same side of each row are connected to each other.
Middle pin is the common pin, it will always be connected
Short version (Aint nobody got time fo that! version):-
Follow this diagram which shows the view on the underside.
Same color pins are same electrically, Pins circled in blue are ones you need.
doesnt work? then solder the middle pin and the pin on the other side.
Detailed:-
Look at the diagram. That will give you what you need.
But what if your new switch is faulty? you need to check. also some manufacturer might have accidentally put the notch on the wrong side. So its always better to check.
To check just connect two rows with the multimeter(still in resistance mode) while the button is not pressed.
If it shows zero ohms, you are using the wrong pins, check the opposite side.
If it shows infinite then you probably have the correct side. Check it again by pressing the switch. Zero ohms now? Great. Leave the two pins, and chop off the rest or bend them in (risk of shorting later)
The home stretch
All that is left now is putting it back together.
First solder off the two wires to the two pins on the switch.
Cover the leads with liquid electric tape or hot glue. I have neither so i stole some nailpolish, which is great too.
Dont put the switch in before you apply hot glue and stuff. You risk jamming the switch in permanently otherwise. Wait till the stuff dries.
Now put in the Plastick switch in first. make sure its the correct way round not upside down XD
There is a hole in the plastic bit in which the push buttons tip goes in as shown in this picture.
Press the superficial switch all the way in. Orient the push button switch correctly (the holes are rectangular, so they wont fit every way) and slide the switch in gently.
Push the button a couple of times to check.
Hurrah its done. You have earned yourself a beer
You will need:-
- Needle Nose Pliers
- Tweezers
- Small flat-head screw driver
- Soldering wire and flux
- Sandpaper, 320grit
- Sharpie
- soldering iron, min 25W
- liquid electric tape/hot glue/both
- Basic soldering skills and multimeter usage skills
Reason for failure
Fixing the problem
Detailed:-
The home stretch
