power saving mode after a few minutes on gaming
omrimega
4 (0.00/day)
System Name Windows 7 Ultimate
Processor Intel Core I5 760
Motherboard P55A-UD3
Memory 4096MB RAM
Video Card(s) ATI AMD HD 6850
Storage hard disk 500giga
Display(s) 22 inch LG W2243T
Case Antec ThreeHundred
Power Supply SeaSonic 620W
Hello everybody,
i playing max payne 3 and a few minute after the screen into a mode power saving mode..
the computer stuck and the sound like a buzzy
the problem stay on a many games
in borderlands
gta iv
and more..
but not all!!
i have a gaming computer:
I5 760 2.80GHZ
Memory 4096MB RAM
motherboard: P55A-UD3
GPU: AMD ATI 6850 HD
WINDOWS 7 64BIT
i tried to format my computer and the problem didnt solved..
i changed the power settings in control panel
i replaced the lithium battery in my motherboard
but the problem didnt solved
i try to use a software for check the temperature and the memory of the video card and i see a problem
please download the log to see my problem
http://www51.zippyshare.com/v/70845650/file.html
go to down and see the memory of the card
from 10:15:59 the problem start
from 10:16:05 the computer do a restart
link doesn't work
as Wizzard says the links broke,
what graphics card driver are you useing, version number??
Run Memtest on your ram and see if you get any errors.
Try running the games without any Antivirus programs running in the background.
Fill out your system specs in the User CP and click on the show box.
Are you using onboard sound or sound card?
EDIT: Also, check the event viewer in your administrative tools to see if anything or what is happening when the problem occurs, such as, misbehaving drivers/services/scheduled events/etc.
What PSU are you using to drive this puppy?
link doesn't work
The new link: http://www51.zippyshare.com/v/70845650/file.html
the new link : http://www51.zippyshare.com/v/70845650/file.html
and my card driver version is 12.6
the problem doesn't related to the antivirus
i tried all the options please help me
and about the sound card i think its connected to the moderboard like a onboard sound
sea sonic 620W
please help me
Hello everybody,
in borderlands
gta iv
and more..
but not all!!
I5 760 2.80GHZ
Memory 4096MB RAM
WINDOWS 7 64BIT
Your description worries me, it sounds just like when my former graphics card was dying, screen turns off windows stuck and a buzzing sound coming from speakers, when did this start happening.
To eliminate hardware fault do you have a spare graphics card\better PSU to test in your PC?
i dont have a spare graphics card..
My friend had a similar problem on his older desktop. if its similar it is a problem with your graphics card overheating or dying. two steps to take would be to open the computer and clean the graphics card cooler thoroughly. And second of all get a friends graphics card and try his in your computer. this will rule out completely any problems with your graphics card. Which i think it is.
Btw. its not your pc outputting "power saving mode". but instead its the monitor saying power saving mode since your graphics card is crashing and the screen is not recieving a signal and going to standby.
Is every game goes blank after a min or 2 min use a stopwatch to get that exactly, After that done keep your mouse moving everytime and see if it goes blank or not.
If this does not helps you then this is not a Power Option Problem, Maybe there is a option of this in the AMD Driver Settings explore the settings and see if you find something that helps, I don't have a GPU so i cannot tell about GPU driver.
