PowerColor to Release AGP version of Radeon X1950 Pro
malware
5,422 (0.72/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
According to DailyTech, PowerColor will be releasing a Radeon X1950 Pro based product for AGP systems. Images of the proposed Radeon X1950 Pro AGP graphics card are also revealed. The upcoming Radeon X1950 Pro AGP is expected to be clocked higher than its PCI Express counterparts at 600 MHz core and 700 MHz instead of the 575 MHz core and 690 MHz memory on PCI Express version. In addition to the higher core and memory clocks, PowerColor will equip Radeon X1950 Pro AGP graphics cards with a quiet Arctic Cooling Accelero X2 cooling solution. If this thing really hit the market, this will probably be the fastest available AGP video card.
I was planning on upgrading my SFF AGP card with one of these. I guess that's impossible now since they made it a two slot cooler. Morons.
I dont think the 2 slot cooler thing is stupid.
Bc if they didnt make it big and powerful enough then it will easily kill the card or drastically shorten the life of the card.
Its better to be safe then sorry.
Isn't AGP supposed to be dead already?
@mnm222876, just replace the two slot cooler with a one slot cooler and downclock the core and memory and you'll be OK. In the last yeas, I've made SO MANY home-made coolers for various SFF. You need a workbench, a saw, a dremel, and a threading tool and you can make any shape of cooler you want.
I got my home-made SFF Pentium M 1.5Gz totally silent this way. You can do it too!
Reason that its being sold as a 2 slot? Retail value-added, and quieter. Nearly all enthusiasts put an aftermarket cooler on their GPU, so they are doing this as part of the original package. For 90% of buyers this is a good thing and a lower cost overall. Downside to single slot fans, but you can fix it.
Plus you could always buy another brand....They may not all have a double slot cooler on them.
In regards to 2 slot coolers. I fell they should all exhaust out of the case. If they are going to put that much cooling power onto a card then expell all that hot air instaed of just circulating it inside the case.
If this card is to be had on the market, then ATi will still be King of AGP. :D
My question is:
Is it worth paying for this when you have maybe the second best agp card with an ATI X850Xt? Definately will need to see some benchmarks.
One other thing:
I suppose this will run DirectX 10 and have all the latest eye candy thingies..?
I dont know.
But from what I have heard they say that the 8 lanes on the AGP bus is not enough and will bottleneck this GPU, unlike the PCI-Express version.
If this is true than this card will be the first to do so and will show that the PCI-Express version is better than the AGP.
the 8 alnes is prolly enough its not a dual card like the nvidia gx2 so it should work ok now im not sying it will be faster just i prolly wont bottleneck and btw what is the pricing going to be im thinking about as much as a used car but thats just me :D
@GLD, I agree. Two slot cooler should exhaust the hot air, not just spin in into the case.
@AnneCore. Yes. Just compare PCIe X850 vs X1950pro. Big difference. Second. Encoding DivX. That ATI codec that operates 8x faster than a standalone CPU means you can encode a DVD in tens of minutes not hours. Third. Dual-link DVI to drive 2 TFT's or a super hi-res TFT like the Apple Cinema Display 30". You can't do that on an X850.
@bruins004. Most tests to date show that the AGP isn't even saturated yet. So in theory although the PCIe lane has 2x the bandwidth (one way... since we write, dont read to the GPU), it makes no performance difference.
AGP was originally designed to deal with ripping textures from main memory onto the GPU which (5 years ago) had only 8 or 16MB of RAM. Now that GPU's have 256MB or 512MB, there really isn't that much data going from main memory to the GPU. If there is any transfer, its coming off the HDD. And that's the bottleneck. The HDD interconnect, not the GPU interconnect.
So I think the benchies will show identical performance.
@cdawall, good point. Many SLI /Crossfires are NOT BOTTLENECKED when the second card is on PCIe4 or PCIe8 (in a 16 slot, but only 4 or 8 connections).
If not bottlenecked at PCIe4, then with AGP the speed is 2x > than PCIe4, there wont be a problem.
its agp 3.0 not 2x and anything less than agp 3.0 which is 8x and it will bottleneck at agp 4x and wont run in 2x b/c diff volts
did his little symbols not mean that as AGP is two times greater PCI-E x4 is, and therefore if PCI-E x4 doesn't bottleneck neither will AGP :confused:
Let me rephrase that to avoid confusion:
1./ There are many versions of AGP. What I am refering to, and only refering to, is AGP version 3.0 also known as AGP 8x with a bandwidth of 2112MB/s. I will refer to AGP 3.0 (8x) as AGP for short. Any mainboard with a lower AGP specification is an old dinosaur and is not part of this discussion.
2./ PCIe16 has twice the "one way" bandwidth compared to AGP. PCIe16 can sustain 4000MB/s one-way.
3./ Because PCIe16 can read and write in both directions, sometimes PCIe16 is claimed to have 8000MB/s bandwidth that is nearly four times the bandwidth compared to AGP.
4./ However, since we "write" and dont "read" to GPU then this point is moot.
5./ Hence, from a GPU perspective, we can think of the PCIe16 as being twice as fast as AGP, 4000MB/s compared to 2112MB/s. Also, PCIe8 is about the same speed as AGP in graphics bandwidth terms, 2000MB/s compared to 2112MB/s.
6./ For interested parties, the bandwidth obtained through simultaneous read and write IS VERY INTERESTING for network cards. Basically a PCIe1 network card can operate at 2-4x the throughput of a PCI network card. And on a server, you can install network cards with multiple connections that run on PCIe4, which has 8-16x the throughput of a PCI card. PCIe also doesn't "steal" bandwidth from other slots. Whereas on PCI, this bandwidth is shared across all PCI slots.
For reference:<div align="center"><table width="60%" border="4">
<tr>
<td><div align="center">Graphics Standards</div></td>
<td><div align="center">Possible Bandwidth</td>
</tr>
<tr>
<td>
<div align="center">16-bit ISA</div>
</td>
<td>
<div align="center">16MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">EISA</div>
</td>
<td>
<div align="center">32MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">VLB</div>
</td>
<td>
<div align="center">132MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">PCI</div>
</td>
<td>
</td>
</tr>
<tr>
<td>
<div align="center">AGP 1x</div>
</td>
<td>
<div align="center">264MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">AGP 2x</div>
</td>
<td>
<div align="center">528MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">AGP 4x</div>
</td>
<td>
<div align="center">1056MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">AGP 8x</div>
</td>
<td>
<div align="center">2112MB/s</div>
</td>
</tr>
<tr>
<td>
<div align="center">PCIe x1</div>
</td>
<td>
<div align="center">250 / 500MB/s
(Per direction / Both Directions)</div>
</td>
</tr>
<tr>
<td>
<div align="center">PCIe x2</div>
</td>
<td>
<div align="center">500 / 1000MB/s
</td>
</tr>
<tr>
<td>
<div align="center">PCIe x4</div>
</td>
<td>
<div align="center">1000 / 2000MB/s
</td>
</tr>
<tr>
<td>
<div align="center">PCIe x8</div>
</td>
<td>
<div align="center">2000 / 4000MB/s
</td>
</tr>
<tr>
<td>
<div align="center">PCIe x16</div>
</td>
<td>
<div align="center">4000 / 8000MB/s
</td>
</tr>
</table>
Now the main point is this. If AGP is as good as PCIe8 and is 2x the speed of PCIe4. But we know that PCIe4 and PCIe8 are good enough for SLI and crossfire, then we know AGP is also good enough and we will not hit a bandwidth problem on AGP.
Well put lemonadesoda but I think the part of the problem with bottlenecks today is the CPU too. With new high end cards and all the eye candy maxed the CPU seems to make the difference between playable FPS and having a slide show. This is where having a newer PCI express system will truly shine.
Another issue for this card if it ever sees the light of day will be cost. AGP versions always seem to cost more and in NVIDIA’s case have fewer pipes too.
So will it even be worth the cost to upgrade now or just save up and upgrade your whole system later? I know some people here argue about waiting for DX10 however if you (we) have waited this long to upgrade why not wait till you can do your whole system and support the next generation of software/hardware.
http://www.dailytech.com/article.aspx?newsid=4702
Actually from the looks of it its clocked higher than the pci-e version and has the same pipes and specs and all that jazz. Only difference is AGP. And if you have a decent CPU to go with this card then its a good upgrade for you.
Currently the pci-e version without the stock cooler cost $164 on newegg. So I dont think this card is gonna get over $210 newegg wise.
tweet this wouldnt be a good upgrade for you because of your cpu. So the move to pci-e is actually your only real choice gaming wise.
Two slut / One slut
Okay, so this card doesn't really NEED the two slot cooler after all. The GeCube version will be clocked the same as the PowerColor and the GeCube is using the one slot cooler.
I will buy the GeCube version, problem solved.
This could probably be the last and best only card for AGP.
That's why I want to grab one for my No.3 machine before AGP dies for good. My No.1 and No.2 machines are more modern with PCIe.
It's funny how people think that AGP is so out of date, but yet its interface bandwidth has not yet been exceeded for single card solutions.
Well I would consider getting one but TBH I need a few upgrades, like a move to Conroe, and as PCI-E tends to be cheaper I would probably just get one of those and a PCI-E mobo. Nice that PowerColor are supporting AGP, but I'm not getting any more of them. Anyway, my next upgrade will still be a while away.
this card is good for people who have second/third comps with agp, or even people with only 1 agp comp who cant afford a new cpu and mobo :D
I wouldn't splash out this much money on a 2nd/3rd computer though...
if your like me, and have brothers that play games on the other computers 'occasionally', its good to have a card like this around, so i can upgrade my x800 and give it to them :p, or when they are cheap enough they will b good :)
I think it will be a nice card to have in order to have the greatest and last agp card to see off dx9 and agp together. will make a nice card to ma out my 3200xp machine and keep it usefull enough to play current games for a while yet. not my main machine but the machine is used for lan gaming. Im waiting for dx10 before getting a pcie card for current machine.
