Problem when restarting windows
TakeshiCyborg
4 (0.40/day)
When I restart Windows, ThrottleStop doesn't load with the desired frequencies and/or FIVR settings. To get everything working right, I have to switch between profiles. Is this a known bug?
P.s. I've set ThrottleStop to start automatically (with admin privileges) through the Task Scheduler
TakeshiCyborg
4 (0.40/day)
ThrottleStop starts up consistently for me.
Post screenshots of the main ThrottleStop window, the FIVR and TPL windows.
Do you have Intel XTU or any other CPU management software installed?
AFTER SWITCH PROFILES AND SAVE FREQUENCIES WORKS
I don't know why I have xtuservice, I had uninstalled xtu via revo uninstaller
I have not installed cpu overclocking in clevo control center, in fact if I press cpu overclocking it asks me to install it
unclewebb
8,348 (1.35/day)
I disabled xtu startup in services and now throttlestop works fine at windows startup.
You are the second person just recently to report problems because the XTU Service was still running in the background even though they never installed XTU. Some manufacturer's use the XTU library in their control software so they do not have to write their own CPU voltage and speed control software. XTU Service can and does interfere with ThrottleStop. I am glad to hear that you were able to get this problem figured out.
