problem with Bios of xfx radeon hd 6950 2gb help
LION777
3 (0.00/day)
Compré la tarjeta gráfica usada y al instalar el controlador había una pantalla negra y los ventiladores al 100%
al comprobar con gpuz los valores de la bios estaban equivocados, fkashee con atiflash con éxito, pero todavía los valores siguen siendo incorrectos y no da vídeo
I bought the used graphics card and when installing the driver there was a black screen and the fans at 100%
when checking with gpuz the bios values were wrong, fkashee with atiflash successfully but still the values are still wrong and does not give video ...
I'm sorry I don't speak English, I use the translator, I would appreciate your help
Read this guide to learn how to recover the original BIOS.
Original BIOS
BIOS with unlocked shaders
thanks for the reply,
I had flashed that bios but it remains the same, this 6950 is the one with the fan in the center, I tried several bios and continue with that image error
BIOS flash is not a solution to repair defective cards.
If this issue appeared without you flashing a wrong BIOS, the card might be just dying.
Clean the graphics card with alcohol & cotton swabs and then reapply thermal paste.
If still not working, you can try to reflow the circuits with the oven trick.
HD 6000 series are 10-year-old, maybe its time for an upgrade.
I managed to flash the correct bios, now I have an image, the problem is when installing the driver the fan is set to 100% and it does not give video, maybe it needs a reflow as you indicated.
