Problem with integrated graphics
AlexDeForce
15 (0.01/day)
Hello
My question is this: I have an intel core i7 3770 with an asrock h61m-vg3 motherboard, 16gb ram, 1tb mechanical hdd
My problem is that when I try to play with the integrated intel hd 4000 graphics the computer freezes and I have to turn it off by removing the power a few years ago I tried games like fortnite pubg lite among others and it worked normally.
I would like to know what could be happening and it could be the processor or in this case the motherboard, I don't know if it could be the motherboard.
One last thing when I use a video card, the games work fine for me without any problem.
5,685 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
What PSU (power supply) do you use and how old is it
because that sounds like it's going into OCP (Over Current Protection) mode or UVP ( Under Voltage Protection ) mode
please also fill in your system specs in your profile this helps us to know what hardware you have and speeds up replies for help
AlexDeForce
15 (0.01/day)
It's a 250 watt dell power supply.
Which has a silver certification label.
I have another evga bronze 600 watt power supply, should I try that one?
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
250W was barely adequate to start with and all PSUs weaken over time. "IF" you are certain that is not a proprietary supply (something Dell is notorious for using! :(), I sure would try the EVGA.
An easy way to check for compatibility is to use a PSU Tester. If main power connector connects to the tester without problems AND the voltages all appear correctly, the supply uses industry standard connectors, is wired to ATX Form Factor standards, and not proprietary.
You also need to make sure the interior is clean of heat trapping dust and that all fans spin freely.
5,685 (1.02/day)
Gougeland (NZ)
Yes try that see how you go
Like using server grade PSU's in desktop atx systems and then it's good luck in getting a larger wattage one if you upgrade your system and need more power to run it 99% chance you'll be SOL from Dell
AlexDeForce
15 (0.01/day)
I have tried with the evga source and it still gives me the same problem, I don't know what else to do or what else to discard.
4,628 (0.74/day)
where everyone wants to be
System Name Everchanging
Processor AMD Ryzen 9 5900X
Motherboard ASUS ROG Crosshair Dark Hero
Cooling Arctic Cooling Liquid Freezer 2 420mm
Memory 2x16GB Corsair DDR4 3600 CL16
Video Card(s) eVGA RTX 3090 Ti FTW3
Storage Samsung 980 Pro 256GB, Samsung 980 Pro 2TB
Display(s) 2xSamsung 28" 4k HDR 144Hz
Case Fractal Meshify 2 XL
Audio Device(s) fiio K9 to Hifiman Sundara's via 4.4mm balanced cable
Power Supply Seasonic Prime TX 850w
Keyboard Corsair K70 RGB PRO
Software Windows 11 x64
If using a dedicated GPU doesn't cause the issue, but only using the iGPU does, than likely the iGPU/CPU is the problem. If you have a spare MB or CPU, or a friend has one you can use, try your CPU in another motherboard, and another CPU in your motherboard.
