Problem with my power inverter
Yeah I looked on there one day.. I really need to get some deep cycle batteries before I do anything else really,I was only using one normal car battery and it just worked it to death..
I am not sure if a transformer can help you with problems by using a modified sine wave inverters. Modified sine wave inverters are of course cheaper and can be used with most devices except the sensitive ones if you can tolerate the buzzing sound they produce. If you don’t like the buzz or if you want to use the inverter or UPS for more sensitive devices like computers and digital clocks, I suggest you to try an exchange your existing MSW inverter with a PSW inverter. Yes, it is a little more expensive option, but it will definitely be a better option.
