Problem with nvflash(nvdia flashing tool)
MrHijacked
3 (0.00/day)
because im having some display issue when i recently installed a clean os im trying to flash an updated BIOS of my gpu but im having this problem with nvflash where when i try to type in the command box every letter i type it just scrolls down and it doesnt let me type anything, for example i press n it moves me to a section, i press v it moves me down again
3,086 (0.53/day)
MN
System Name Personal / HTPC
Case Titan Silent 2 / CM HAF XB Evo
Doing a BIOS flash on the GPU shouldn't be necessary if things were working before your clean OS install. To me, flashing the BIOS on a GPU is meant for two things:
1) Being an extremest - someone that wants to fine tune and get the most out of their GPUs
2) Very last ditch effort to fix a GPU if all else fails.
A clean OS install should not require you to flash the BIOS on your GPU.
W1zzard
Administrator
28,614 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
You need to type the nvflash command parameters after the nvflash name.
It has no gui, so you need to feed it command line arguments
MrHijacked
3 (0.00/day)
thanks for your reply but as i said it doesnt let me type anything so idk how im supposed to do that
W1zzard
Administrator
28,614 (3.74/day)
Memory 48 GB
start an elevated command prompt, navigate to the folder with nvflash using cd and other commands, then type nvflash and the parameters.
MrHijacked
3 (0.00/day)
thats what i did but when i get to nvflash it still doesnt let me type anything
