[Case Gallery] Project Pimptight
bigboi86
1,442 (0.21/day)
techPowerUp!
System Name Just getting started....
Processor Athlon II Propus 620 @ 3.51ghz (quad core) L3 cache enabled
Motherboard ASUS M4A785TD-V EVO
Cooling Cooler Master Hyper 212 (great heatsink, 40c max load overclocked)
Memory Kingston HyperX DDR31600 4gb 2x2
Video Card(s) ATI Radeon HD 4850 by XFX
Storage Western Digital Caviar Blue WD3200AAKS 320GB SATA
Display(s) Acer 21.5 inch viewable G215H 1920x1080p, AOC 22inch 1680x1050
Case Antec 300, stock for now
Audio Device(s) Onboard, Turtle Beach headphones / crappy logitech desktop speakers
Power Supply Corsair 650 watt PSU <3
Software Windows 7 x64
Specs:
AMD Athlon X2 4200+ 65watt @ 2.8ghz 1.4v, Biostar Tforce 6100AM2, 2gb Corsair XMS2 675@800mhz 4-4-4-12 1t, 8600GT @ 700/950, Western Digital 160gb Sata, Lite-On DVD DL Burner, Logitech z-5300e Speakers, Acer AL1716 DVI Monitor, OCZ GameXStream 600watt SLI PSU
Mods:
The only casemod I've done is cutting the metal fangrill out in the front of the case, and removing the foam "filter" material out of the mesh in the front, increasing airflow by a large amount and adds some style to the plain looking case.
Heh Theres really not much there for us to base any rating...
a pic of your mouse and sub... o_O
and pic of the lit up fan in the front
if you dont have some crazy side panel window or some crazy custom case might as well show us the inside...ie, WIRE Management
another thing you have 5.1 surround sound speakers but why do you have your rear satellite speakers on your desk infront of you?
This is a temporary setup, it's on a table in the main room of the house, no walls or anything to mount speakers on behind me. The wire management isn't the best, I don't have a window in my case right now so I don't really care.
You are supposed to rate the PC on looks, parts, etc. How is it not evident what I have in the pictures?
Anyways, here are some inside shots.
