PSP Emulator
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Hi all!
I was playing medievil resurrection on a psp emulator, but i get very low frame rates
like 7-9 FPS!
Anyone has any experience to help me out? I cannot figure out why this emulator runs so slow.
It is the java emulator Jpcsp v0.6 2643
6,881 (1.42/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
3,352 (0.60/day)
Case Zalman S2
As soon as i downloaded it, it crashed.
Tried it 12 other times, all crashes
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
i assume it's because it is written in java. no offense to the language, but a game platform emulator is not the idea program to be written in java.
sorry i don't have any alternatives for you. didn't mean for this post to be all negative.
3,352 (0.60/day)
Case Zalman S2
I understand your negative impact, as it is the only emulator that has worked....
BTW, i greatly hate java
582 (0.09/day)
Dallas, Oregon
System Name Custom FX
Processor AMD Ryzen 5 1600X @ 4Ghz
Motherboard MSI B350 Tomahawk
Cooling EK A240 Kit
Memory G.SKILL G.SKILL Ripjaws V Series DDR4 3200 8GB
Video Card(s) EVGA GeForce RTX 2070 FTW3 Ultra
Storage SAMSUNG 960 EVO M.2 250GB NVMe OS Drive/Seagate Hybrid SSHD ST1000LM014 1TB MLC/8GB 64MB Cache
Display(s) ASUS VE228H 21.5 inch
Case Raijintek Thetis
Power Supply Silverstone Strider 750 Plus 750W Modular
Mouse Red Dragon M715 Dagger
Keyboard Corsair Strafe
You could try the more core version of what you have been trying called PCSP its kinda the same of what you have been useing but remove the JAVA part heres a link
http://www.pcsp-emu.com/news.php
naoan
303 (0.05/day)
System Name AMD?
Software 7 X64
No other PSP emulator offer better compatiblity and speed than JPCSP currently, believe it or not.
Not sure with your game but an almost sure fire setting for this emu is as follow:
And force disable vsync on catalyst/vision control panel, this is really important.
Note: Disable Only GE Graphic option if you got flickering or black screen.
3,352 (0.60/day)
Case Zalman S2
I would really like to make changes, but now, no matter where i run the emulator it goes full screen and i cannot make any changes!
Do you know how to get back to windowed mode?
naoan
303 (0.05/day)
System Name AMD?
Software 7 X64
Yeah, just right click or press f2. If that fail as well, just delete the setting.properties on jpcsp folder, it'll revert to default setting.
3,352 (0.60/day)
Case Zalman S2
I deleted the config file and it got windowed mode again
Where did you get that window? I cannot find it in the emulator
Where can i disable vsync on catalist?
Also, why do i get 7-9 fps? Because of low power of cpu? or gpu?
My cpu is being used like 85% and ram 48%
I cannot imagine what powerful computer is needed to run PS3 or Xbox 360 games!
naoan
303 (0.05/day)
System Name AMD?
Software 7 X64
I'm using JPCSP launcher, but the option is all there on the native program. As with all emulator, sometimes CPU and GPU requirement shoot through the roof depending on the game.
3,352 (0.60/day)
Case Zalman S2
Your options are very different!
Can you make a screenshot to the program opening screen?
I get this on options->configurations
And this is your options screen on my version
Redit: YAY! I changed my options identical as yours and it works to 15-30 fps :)
At least now i get double fps
Thanks!
(i guess my version is the latest one)
3,352 (0.60/day)
Case Zalman S2
Ok, actually i tried it and after 5 minutes it crashed.
Display driver currently stopped!
Is there any option i need to disable?
naoan
303 (0.05/day)
System Name AMD?
Software 7 X64
That symptom usually mean either the driver is wonky (since JPCSP use OpenGL) or your card is failing.
Also, sometimes PSP games lock fps at 15, 20 or, 30, and currently there's no option to disable frame limit on JPCSP.
3,352 (0.60/day)
Case Zalman S2
Would it be the card, even if i play Modern Warfare 3?
