Question for ReLIVE / VCE users
105 (0.02/day)
System Name Custom build
Processor AMD Ryzen 7 5800X
Motherboard ASrock B550M
Cooling Wraith Max
Memory DDR4 4000 16x2GB
Video Card(s) RX 6900 XT
Storage Sabrent Rocket 4.0 500GB
Display(s) ASUS VG236H 120Hz
Case N/A
Power Supply Thermaltake 850W
Mouse Generic
Keyboard Generic
Software Win 10 x64
Hello
I'm wondering if any of you wonderful people that are using AMD's video recording ReLIVE can help me with a thing.
I currently record my video games with Shadowplay, but looking to build another system - I need to know what kind of settings and stuff ReLIVE records with
Specifically, I need the mediainfo (or equivalent) for an AMD recorded file medinfnvd.jpg - the one I attached is for Shadowplay recorded one.
It shows the codecs/framerate/profile/etc.
I've been trying to get my hands on an untouched/raw AMD ReLIVE recorded file to check mediainfo myself but all I keep finding are some sort of altered file, be it uploaded to a video sharing site or
edited in software. I just need either the mediainfo of a raw file or like a 5-second raw .mp4 to check myself. AVC/H264 prefered but if someone can do both AVC/H264 and HEVC/H265 that would be the best.
Thanks!
Hello,
with max recording bitrate set to 30 Mb/s the following file was produced:
Code:
General
Format                                   : MPEG-4
Format profile                           : Base Media
Codec ID                                 : isom (isom/iso2/avc1/mp41)
File size                                : 218 MiB
Duration                                 : 1 min 0 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 30.4 Mb/s
Writing application                      : Lavf57.71.100
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L4.2
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 4 frames
Format settings, GOP                     : M=1, N=30
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Bit rate                                 : 30.1 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Variable
Frame rate                               : 60.000 FPS
Minimum frame rate                       : 59.796 FPS
Maximum frame rate                       : 60.015 FPS
Standard                                 : Component
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.242
Stream size                              : 215 MiB (99%)
Color range                              : Limited
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : LC
Codec ID                                 : mp4a-40-2
Bit rate mode                            : Variable
Bit rate                                 : 309 kb/s
Maximum bit rate                         : 320 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 46.875 FPS (1024 SPF)
Compression mode                         : Lossy
Stream size                              : 2.21 MiB (1%)
Default                                  : Yes
Alternate group                          : 1
