quick partition magic 8 question
3xploit
275 (0.04/day)
Canada
Processor i7 920 @ 3.9ghz 1.33vLoad
Motherboard evga x58
Cooling TRUE
Memory 6x1gb Aeneon 1600
Video Card(s) GTS 512 820/2052/1107 + accelero s1 (2x 120mm fans)
Storage Western Digital 500gb SATA
Display(s) ViewSonic 22" 1680x1050
Case Antec Three Hundred
Audio Device(s) ONBOARD
Power Supply Tuniq 5501
Software Windows 7 x64 7100
right now i have two partitions on my hdd, both have xp installed. I want to to delete the first partition, c drive, and put the free space in the second partition, d drive. In partition magic i did the following things:
delete C drive
allocate free space to d drive
if i click apply changes it gives me the warning: "there is no active partition. are you sure you want to apply changes?" so i click no and now i'm stuck. also i cannot find any option to set D as the active partition.
in partition magic it says d drive is "logical". should i convert it to "primary"?
if i go ahead and click yes will it mess up my hdd/data?
I have partitioned my C: drive (with my main data) while windows was installed. It worked fine. PLEASE PLEASE defrag first, otherwise it WILL fail.
is it necessary to change d drive to primary?
If I understand correctly:
Windows is installed on C and D
You want to delete C
You wanna take the space from C and put it to D
If so, then make D the primary drive!
