Radeon 9200 Problem
Squall_United
4 (0.00/day)
My card is radeon 9200.i overclock it from 200/166 mhz to 302/164 and i use catalyst 6.4 why if i play game such as FIFA 06 and SRS the graphic was worse than i use original catalyst (4.4) without overclock? Please Help!
2,116 (0.32/day)
System Name Not named
Processor Intel 8700k @ 5Ghz
Motherboard Asus ROG STRIX Z370-E Gaming
Cooling DeepCool Assassin II
Memory 16GB DDR4 Corsair LPX 3000mhz CL15
Video Card(s) Zotac 1080 Ti AMP EXTREME
Storage Samsung 960 PRO 512GB
Display(s) 24" Dell IPS 1920x1200
Case Fractal Design R5
Power Supply Corsair AX760 Watt Fully Modular
when you say graphic do you mean its running more slowly or looks uglier then it used to? And you should update to cat 6.5 from ati's website.
714 (0.11/day)
System Name Xbox 360 Super Elite
Processor 3.2GHz PowerPC Tri-Core Xenon
Memory 512MB 700MHz GDDR3 RAM
Video Card(s) ATI Xenos @ 500 MHz
Storage 250GB
Display(s) 26" Samsung LCD HDTV
Case Super Elite (COD:MW2 Edition)
Audio Device(s) 5.1
Power Supply 120w
Software NXE
try the omega drivers, there better with the older cards
8,253 (1.23/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
go back to your old drivers.. new drivers are tweaked for new cards.. they can go the other way with the older less important ones..
trog
Squall_United
4 (0.00/day)
The graphic was slowly and uglier after overclock.but for game like pro evolution soccer 5 or mechwarrior graphic was better.i use catalyst 6.4 softmodded
