Radiator Fans
[Ion]
WCG Team Assistant
13,391 (2.33/day)
Raleigh, North Carolina, United States
System Name Niedersachsen / Ribe / Minsk
Processor i3 3240 / i7-3520M / 4x Opteron 6376 @ 2.86GHz
Motherboard BIOSTAR H61M / HP Q77 / Supermicro H8QG7
Cooling Stock / Stock / 4x 1U G34
Memory 1x8GB / 2x4GB / 4x4GB
Video Card(s) GTX260 / Intel HD 4000 / nVidia GT310
Storage 80GB Intel SSD / 256GB Intel SSD / 2x 60GB SSD (RAID1)
Display(s) Dell 3007 + HP 2245w / 12.1" 1366x768 / None
Case Antec NSK3480 / HP / Supermicro 1U
Power Supply Enermax 500W / HP 130W / Supermicro Gold 1400W
Keyboard IBM Model M
Software Windows 7 (Niedersachsen/Ribe) / Linux Mint 17.2 (Minsk)
I'm looking to buy three 120mm fans for the 360mm radiator I've put on my newest system. Currently I'm using a Lian Li 120mm fan and a pair of 120mm Cooler Master fans. My goal is high performance but fans that also respond well to a fan controller....being able to run at full speed most of the time but then slow them down and have them still work well is preferred. The big issue that I have right now is that the Cooler Master fans rattle pretty badly.
I don't have a particular price set, but I'd rather not spend more than is beneficial.
Go with Corsair AF120 those are some good fans:toast:
as i read corsair Air Series SP120 High Performance are ok for this use
Do you like leds?
i like a couple of fans...
Coolermaster JetFlo fans,
Thermaltake Riing 12 Fans,
Thermaltake Pure 12 Without led..
also Gelid Extreme slim UV fans With and Without Led are amazing, i have them for top exhaust on my main rig.... :D
Scythe (Nidec Servo Corp) Gentle Typhoons AP15 or AP2150 - Awesome static pressure (2.0 mm H2O) to noise and made for radiator use.
here we still dont got sp120/af120/Riing/Pure:(
but i'm ok with my ooooooold x-silent(on 500 rpm i cant hear them):)
sorry by that... but what about online order?
Swiftech Helix fans are pretty good and they go for around $10-12 each.
Awesome, thanks for the suggestions everyone. I'll check out all of those models.
Do you like leds?
No, definitely no LEDs....room is already bright enough without needing more LEDs on everything.
Is there much of a benefit to going push/pull if the fans are already pretty solid?
Silverstone air penetrator, works fine:rockout:
I run mine in a push.pull config. Just allows me to run everything at a lower rpm while maintaining the same CFM.
cant understand this
understood, are you satisfied with your cooling now(temps) cause from 1st message i thought problem is only in sound(fans are noisy)
if you're satisfied, than you should go for only pushing, if you're sound maniac and play/encode/fulload your system wthout any sound(or got person who hears sound of system while you're using it with headset) than go for push&pull configuration and you got all benefits from good cooling while keeping it in low rpm(less noise)
Well if you use push/pull config you can run the fans at a much lower rpm for lower db and maintain same cooling levels. Plus you then have the option of running them at full speed for great performance when benchmarking or long gaming sessions.
those!!!
Correct...
Temperatures are entirely fine now; low 60s C load @ 4.2GHz is great. Even once it warms up over the summer it'll still be OK....I mostly just want fans that won't rattle.
i thought i wrote same thing but with option: if you realy need it
it's about 45$ o more for 3 high performance coolers
you can buy 5-6(if OP wants to save his old 1) for comfortable use or save those 45$
thats my thought(as it was in my head, sorry for bad english and worser explanation:))
That's not radiator fan.
Maybe 3xSP120 High Performance with 7V resistor or these new EKWB Vardar F3.
Corsair fans are good, a friend got them.
Personnaly, I use XSPC Xinruilian 1650rpm, 6-7$ fans, gentle typhoon performance or similar from test, but sleeved bearing. When tested, they wouldn'T say it is a sleeved cause it is well built.
I got vertically and horizontally, it works nice! no lost of performance. 7 fans I have right now, 5 on Rad
EKWB Vardar fans have been said to be 'Gentle Typhoon killers' given their better than scythe GT performance
I don't believe in that, maybe they are good but I doubt as GT AP-15.
Because I have two AP-15 fans in PC on 1900RPM, MAX speed and I not recognize that fans are in case at all. With open or closed side panel. Only for me Vardar have one flaw. They should made with black ribbon cable as CORSAIR fans.
The only one I was going to suggest was already mentioned (Gentle Typhoons). Just subbing to quietly listen to advice.
if the noise is not a problem then JetFlo (coolermaster)
i used them now i use Corsair SP120L (and no the AF line is a no go for a radiator) @1600rpm, well they are quieter than a 2200rpm JetFlo (not that i cared about noise but my JF "clicked" when fitted top flat)
since it has been already notified then
other contender are E-loop (Phobya, noiseblocker and i don't remember the 3rd brand who has it)
(and the EKWB Vardar but already mentioned too :D )
