Had exactly the same problem and I sorted it out also in combo
Raijintek Morpheus 2 + rx5700 (bios mod to XT), so i´d like to share a little "
how to mount Morpheus II + rx5700XT", because both cards are very similiar and I guess you can use the same method on both of them
btw: Due to binning my rx5700 is performing little worse in terms of temps than a true one
1. Buy "push" fans, that are able to push the air through the body of Morpheus II - I have 2x 120mm Noctua 1700 redux
2. Buy some thermal paste that is on the thicker side - I used MX-4
3. Buy some silicone and plastic washers
Washers are very important - they will not only increase the mounting preassure, but thanks to the flexibility of the silicone, they will also sort some of inaccuracies in pressure.
Something like this:
And now to the mounting:
1. Use more paste than it is recommended by Linus and other youtube gurus (for rx5700 I used about 2 drops of the size of the pea) and spread it evenly, dont use "drop in the middle method" - the process of cooler mounting will screw that up and make it uneven
2. rx5700 core is very small, so the heat transfer from something that small is complicated. So use thermal paste also on the metal square (i dont know what its called) around the core - Morpheus´s contact plate is big enough to have contact with this part as well.
2. Avoid using the back mounting bracket that came with morpheus II - if you have one, then use original one with a square hole in the middle and if you don´t, than pull of the rubber cover and use thick thermal pad instead - the rubber is to hard and could destroy back of the core.
3. Now to the washers - put them between the back mounting bracket and the head of the screws. I wont tell you how thick and how many, because i learned, that different types of rx5700, vegas and VII´s have different hights.
4. And now probably the most important part:
Count how many times you turn each screw. if you dont, youll end up with uneven mounting, which is the cause of 110°C + hotspot.
5. And obvious - do not overtorque the screws
So to the conclusion - Washers + counting how many times you turn each screw are the key.
My max temps after 1 hour of playing Witcher 3 on max with 100+fps (Fans are running on 60% or so) :
Gpu: 66°C
Memory Junction: 78°C
VR VDDC: 63°C
Hot Spot: 85°C
VR MVDD0: 52
VR MVDD1: 50
PS: I wont share any pictures - I panicked, when i saw 110°C hotspot and my card looks like an abomination littered with aluminium and copper heatsinks.
