Re-paste my 2080Ti, idle and load temp significantly down
  • Thread starter Deleted member 50521
  • Start date
So my 2080Ti has been overclocked mildly most of the time. As it is approaching 2yrs old I decided to check the thermal paste as I have been seeing some weird fan behavior. Basically when core temp gets to around 80C under load the fan will suddenly spike to 100% no matter what fan curve I set it to.
Some previous discussion here:
Finally had enough of this so I tear it down. And this is what I find:
So yeah, quite a large portion of the die is not actually getting much TIM contact. No wonder it is doing that.
So wiped off all the thermal paste and put some fresh Thermalgrizzly Kyronaut on there. Cool and quiet again. Exact same overlock, same room temperature and same fan profile. I used to get 82~83C under full load in super position 1080p extreme. Now I am only getting 73C under full load. Most importantly, the noise level is waaaay done.
Cannot say I am happy with EVGA's TIM application. But oh well.
3,623 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
That looks to be the worst stock TIM application LOL. I bet you also experienced lots of stuttering in-game, you just didn't notice them. It won't affect benchmark score but if you actively look for 1% low fps you can easily spot them.
Not really. Most of gaming sessions are VR so if there are ANY stuttering I would instantly vomit to death.
I was running a very close to stock OC, +10MHz on Core and +100 on VRAM. I need to use it for lots of CUDA work as well so cannot bear to have it overclocked too much.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
lol, yeah its a good idea to have a big bottle of 91% ISO for re-pasting an evga card.
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
clean it to the edge, don't leave any old paste and residue there
Sloeri007
1 (0.00/day)
Bit of an old thread already, but had exactly the same with my Aorus 2080 Ti....
After 30 secs of playing anything, fans ramped up to 4000+ rpm (fail safe mode)
So for some period i undervolted the card, to keep it within normal temperature's. (0.825 volt for 1500Mhz....)
not really you want to do with a 1400€ card. but at least it stayed below 75°C that way.
i even was in contact with gigabyte, had send logs and a movie, they said it was "normal"....
so decided to take the plunge, and repaste it myself.
i was baffled when i opened it up, there was nearly no thermal paste and it was bone dry. (the GPU was covered properly though, have to give em that)
redid it with Grizzly Kryonaut.
Result : 12 degrees lower temps, and clock is now stable at 1860 at approx 68°C with fans at 85%
Back a happy gamer now.....
2,381 (0.49/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
Yeah I *just* finished this same thing minutes ago. My 2080Ti FE looked just like OP's pic, but even less paste!!! All towards one corner. Fans were going hard core every 5-7 seconds for 2-3 seconds. I never even overclocked this gpu, it's had an easy life. It also made it obvious that my case fans were set up incorrectly, so I fixed that too.
4,914 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
My MSI RTX 2060 had a similar thermal paste spread, the only difference was just a tiny bit of the outer die wasn’t covered. Looked better than @xkm1948 photo shows.
2,307 (1.20/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
I repaste anything i can can get my grubbies under. Laptops, gpus, mbs its the second thing i do. After making sure they work of course. Ive seen some beauts over the years.
4,914 (1.48/day)
I forgot to mention re-pasting the GPU dropped the temperature down into the low 60-70C, and the sudden fan spin-up fluctuations to 100% i was having stopped. Used Arctic MX-4
I also had the sudden spin up to 100% under load, especially during workload that pull on CUDA and Tensor cores together.
250 (0.14/day)
Texas U.S.A
System Name Satan
Processor AMD 2700x with EK waterblock
Motherboard MSI X470 Gaming Pro
Cooling Custom open loop watercooled
Memory 16 GB Corsair Vengance RGB Pro @ 3466 Mhz
Video Card(s) Powercolor 5700 xt with EK full cover block
Storage Intel 660p 512 GB nvme Samsung 860 Evo 1 TB for storage SATA
Display(s) Viotek 32" curved 144 Hz 1440 P
Case Thermaltake Tower 900
Audio Device(s) Realtek onboard
Power Supply Corsair Rmx 750
Mouse Logitech G 602 wireless
Keyboard Corsair K68
Clean and re apply would be the safe bet mate..paste is cheap, however application is not...
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
8 centimeter clearance distance from what even is near to VGA DC fans, this will deliver higher benefits than any thermal paste.
2,381 (0.49/day)
System Name msdos
Processor 8086
Cooling passive
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Mouse serial
Keyboard yes
My 2080Ti was never this quiet from the day I got it, it must've been pasted wrong the entire time. :(
23,893 (6.16/day)
Yeah... I need to go for it as well on my 1080. Just too lazy but its really becoming time.
I'm down to 90% power target now, which is actually also the best 24/7 setting for this particular one, but I see my clocks decrease as ambient goes up during summer, and it seems to be getting worse. A year back I held 1911 mhz at throttle target, now I get 1790 something mhz lol
Still amazes me how versatile and well GPU Boost works with all these changes in conditions.
752 (0.42/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
And that's why the first thing I do with a GPU is tear it apart, repaste, and put it back together. I've seen too many issues with stock applicated pastes, and it takes 15 minutes to do. Case in point, my 1070 has had massive issues the last 2 months after I sold my 2080 Ti. I never remembered it being bad at all, but when I got it I got constant crashes and thermal problems (idle at 50C, load at 85C), not to mention the incredibly annoying fans ramping up to 100%. Had to set a very aggressive fan curve to keep thermals in check, a -200MHz underclock on both VRAM and core, and a much reduced power limit to even get it to not crash under any form of load.
After a couple weeks I decided enough is enough and I opened it up to find a terrible paste spread. Fixed it up with some NT-H1 and bam, good as new. Actually surprised at how good the 1070 holds up 4 years on, what a great value card. I guess the paste was just good enough for the 3 years I used it, and then when it went into storage for a year the paste dried up and when used again it wasn't covering the die anymore. Or maybe it was always bad and I just never noticed because I had it undervolted for the longest time.
I'm sorry to seem mean here, but I have no idea what this sentence is supposed to mean and it's piqued my interest. Are you trying to say a good fan is better than thermal paste at thermal transfer?
1,929 (0.40/day)
Romania
Why don't you undervolt it ? My 1070Ti dropped about 5ºC with undervolt.
23,893 (6.16/day)
That's a lower power target right? Not sure how else you would undervolt it?
edechamps
1 (0.00/day)
I just had a similar issue with my 2-year-old ASUS ROG Strix GeForce RTX 2080 Ti OC: GPU hovering at 80°C at full load, memory temps through the roof (106°C), fan panicking and going 100% every few seconds. A Google search led me to this thread.
As suggested, I changed the thermal paste on the GPU and voila! Problem gone. GPU hovering near 75°C and memory temps around 90°C (even though I didn't touch the memory thermal pads!). Fan now operates at normal speed. So I just wanted to say thank you for the great suggestion!
Deleted member 205776
My GPU sits at ~65C on stock and ~61C undervolted. I think MSI did a good job with the TIM.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
You are digging in the wrong way.
Looking at the fact that the thermal paste has spread past the corners and formed a rectangle, the paste was more than enough.
The real issue relies how straight that vapor chamber bottom is. I bet it is sunken in just like the paste spread out. The die gets unevenly pressured and the actual spots where the paste is missing, where the pressure points are.
1,374 (0.35/day)
Processor 3900X 4.425
Motherboard X570 Tomahawk
Cooling Galahad 360 push-pull
Storage Optane 280gb PCI-E
Display(s) PG348Q
Case Core X71
Power Supply AX1500i
A guy I know always rips apart cards and puts higher quality TIM and pads. It always drops down his temps, but I personally don't do it. New / good GPUs tend to not need it.
5,487 (3.65/day)
Colorado, U.S.A.
Software Windows 11 Home
That is so weird, one can see how the paste was evenly pushed out the edges but then withdrew.
