So, yeah here is an idea that I came up with, chances are that hasnt been done yet. Basically I was thinking about doing this, but as I do not have the resources, nor do I have the time I can't do it. Read on to learn what I'm talking about.
Sanding the copper base down to heatpipe for
dramatically improved performance!
The proven idea is that the extra copper base acts as thermal resistance versus the heatpipe. The copper base enclosing the heatpipe was originally a means to prevent damage to bare dies, back in the P3/Skt A days.
However since most CPUs these days have an IHS this is rendered useless. An example of application is the Xigmatek Line of HDT products, having exposed heatpipes, making their much smaller sized and cheaper products excellent in terms of performance.
So what am I saying?
I'm saying if your CPU cooler has that extra copper block sandwiching the heatpipes sand it down to the heatpipe! But before you grab some low grit sandpaper to tear through that copper you'll have to consider some things:
1. Normal lapping/sanding procedures
2. How thin the heatpipes are - this means you wont be able to have a fully flat heatpipe, therefore sanding the base down to half a millimeter thin-versus heatpipe will still be enough to yield a massive performance gain. Sanding too much, may weaken the heatpipe too much, or even puncture them; effectively destroying your cooler.
3. Retension pressure compensation. Sanding the base down will reduce the height of the base, because it will make it higher from the IHS, therefore you will need to find a means to increase the mounting pressure/height, in equivalence.
Example, you sand off 2mm in thickness off the ultra 120's base. You will use a 2mm thick steel ring to raise the retention bracket so it will have the same mounting pressure as before you lapped. Take note of how the cooler is installed, some retention mechanisms prevent increasing of pressure!
4. What type of method you use to sand. This is VERY VERY VERY important. Dont use a disk sander to thin the base, even if you are good at using it. The vibrations from the disk sander can possibly ruin the heatpipes! You MUST use normal sanding methods, i.e. sand paper.
5. The method of how the heatpipes are sandwiched. If the cooler will clearly fall apart with the reduction of the copper base, please do not continue with this.
So yeah! Who wants to turn their ultra 120 extreme, thats already a good cooler, into a cooler that performs almost as good as water cooling? (ask your manufacturer for what type and how thick the heatpipes of your cooler are, if you want to sand into the heatpipes)
